Username Post: Can any one help identify this clip?        (Topic#353845)
Mja1975
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
11-10-18 09:16 AM - Post#2750983
Good Morning,
Can anyone help? This clip is in the cluster area where the dash harness would wrap around steering harness. Is this a ground if so for what? Or is it a clip for connectors? Thank you!
Attachment: 15418700229617925485306417123782.jpg (3.19 MB) 4 View(s)
Attachment: 15418701082758540261565993203677.jpg (3.65 MB) 1 View(s)
1967
307
400 Turbo
59fins
59fins
Loc: Surprise Az USA
Reg: 04-07-00
11-10-18 11:04 AM - Post#2750999
    In response to Mja1975
They usually use that type of clip at a place where and wire connector would be on a harness, (not a ground) the "barbed " part would slide into the black plastic connector and secure it ( in this case to the steering column brace, what that exact one is for I am not sure.
If you look at wires in the area of the clip with a connector, you could probably see where in belongs, it can slide back in if someone didn't pull it too hard and break the plastic connector.
It's not real clear, but the brown wire and black wire in the photo go into a connector without being plugged in, that "Could" possibly be the the connector
Bill H.
67 Impala SS
Mja1975
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
11-10-18 11:22 PM - Post#2751037
    In response to 59fins
This is a picture with the entire harness removed.I agree it is a holder for the connects.
Thank you!
1967
307
400 Turbo
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
11-11-18 11:18 AM - Post#2751065
  • Mja1975 Said:
Good Morning,
That is the one that slides into the half moon turn signal connector so that you can clip that connections up out of the way.
Donny
Mja1975
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
11-11-18 12:57 PM - Post#2751072
    In response to aawtech
Thank you very much Donny.
1967
307
400 Turbo
Execution time: 0.07 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:43 AM
