Username Post: Steering Damper?        (Topic#353837)
TYTILIDIE
Gold Supporting Member
TYTILIDIE
Loc: Colorado Springs
Reg: 10-21-15
11-09-18 05:39 PM - Post#2750928
I don't suppose there was one for these cars? When I hit a bump at 40+ I get the death wobble. I have to slow WAAAY down to get it to stop. Odd thing is, it was fine yesterday when I drove it home. I took it to get brakes bled and alignment today and they said they couldn't do it because of the fenders.
The alignment isn't terrible either. Everything is new and seems tight. Any thoughts?
Me
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
11-09-18 06:08 PM - Post#2750933
    In response to TYTILIDIE
What do you have for steering? Stock?
Member #2194
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
11-09-18 06:26 PM - Post#2750935
Find an older alignment shop. The newer equipment cant align the older vehicles due to their equipment design. Newer machines require 4 wheel calibrations and they body of our vehicles do get in the way.
No damper required if aligned properly.
Jeff
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
Edited by Original58 on 11-09-18 06:26 PM. Reason for edit: No reason given.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-09-18 07:15 PM - Post#2750944
    In response to Original58
Find a different shop. There is nothing specail or unusual about aligning a 1959....problem could be that you are usung non-stock suspension parts.
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
11-10-18 04:25 AM - Post#2750961
    In response to Gene_Schneider
It's all stock steering parts. Not original by any means but stock.
Could it be that the tires are too big? I have the H78's on there. Those are a 15" wheel and the tire height is 29".
The alignment issue seemed to be that their equipment doesn't fit on the wheel because of the fender and quarter panel arch. They said it blocks them from installing the parts.
Me
DonSSDD
DonSSDD
Reg: 08-21-01
11-10-18 07:35 AM - Post#2750970
29 inch is tall, is the H78 wide too? What offset on your wheels?
I’ve seen the death wobble on lifted trucks with large rubber, could be something similar happening here. Got a set of smaller tires and rims to try or a set you can borrow? I have a tall tire on the front of my car and I’ve never had anything like a death wobble or heard of anyone else having that issue, but 29 inch is really tall compared to stock which is about 26 inch.
Find out from a friend with an old car who they get to do do their wheel alignment.
Member #2194
DonSSDD
DonSSDD
Reg: 08-21-01
11-10-18 07:44 AM - Post#2750971
    In response to DonSSDD
I checked a converter and that’s about a 235-70-15 which is 9.25 inches wide, that’s a real big front tire and likely a good chance it’s causing your wobble, check the smaller tire Nd see what happens.
Are you getting any tire rubbing?
Member #2194
Edited by DonSSDD on 11-10-18 07:48 AM. Reason for edit: No reason given.
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
11-10-18 03:43 PM - Post#2751018
A friend of mine sons run a tire shop that he started many years ago and he had a couple of classics and did and still does a lot of work on these old cars. I attached a picture of mine being align, he couldn't finish it at the time and I have got to take it back but he had to add extensions on the parts that attach to the tires because of the problem that you mentioned. Lamar
Attachment: IMG_4581_-_Copy__3_.JPG (422.27 KB) 3 View(s)
11-10-18 05:27 PM - Post#2751021
Too much play in the steering box can cause this.
ragtp66
ragtp66
Reg: 12-09-07
11-11-18 06:33 PM - Post#2751091
If you are running the stock ball bearing front wheel bearings I would check both the bearings and inspect the spindle where the bearings ride for any pitting. scoring or unusual wear. Make sure the ball bearings are adjusted properly also. Tighten the spindle nut while rotating the tires to 28ft/lbs then back off the nut and re-tighten to 12 ft lbs. If the castle nut does not align to insert the cotter pin back the nut off until you can insert the cotter pin.
For what an alignment shop charges you can pick one of these up and do a better job then 95% of the shops out there.
https://www.amazon.com/PMD-Products-Camber-C aster-...
I would switch over to the 61-67 hubs and use the taper bearings to be honest its a much better design and much easier to get the taper bearings.
Toys:
1987 Sea Ray Pachanga 22
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
11-12-18 06:34 PM - Post#2751207
    In response to ragtp66
Car was aligned and still does it. It has to be the tires. I built this today. It's bolt on so we'll see what happens when the snow melts.
Me
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
11-13-18 06:41 AM - Post#2751240
From the pics, there is nothing 'stock' about your steering or suspension (or brakes). Everything appears after market. Stock/OEM alignment numbers are not appropriate.
To begin trouble shooting your problem you need accurate info on what you have.
Just trying to be helpful.
Pete
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
11-13-18 05:26 PM - Post#2751317
    In response to japete92
Fair enough.
Global west upper and lower control arms.
Pirate Jacks disc brake conversion (no idea what materials were used. I'd assume Autozone or the cheapest thing they could find.
Factory Spindles
Moog Ider Arm
Moog Pitman Arm
Moog Center Link
Factory Sway Bar
Energy Suspension Sway Bar Hardware
Coker 15" Wheels
Coker H78 Bias Ply Tires
Moog Inner Tie Rods
Moog Outer Tie Rods
Moog Tie Rod Sleeves
Borgeson 605?? Box
Borgeson Steering Shafts (2 joints)
So stockish?
The plan right now is to see if it goes away. I don't know why it hasn't occurred to me to do a good shake down, I'll hopefully have time to do that tomorrow. I made this thing bolt on so I don't have to booger up the car.
Me
11-13-18 06:14 PM - Post#2751324
You shouldn't need a damper if everything is set up right. Did you get a print out with the alignment? Is the there any play in the steering off the center position?
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
11-14-18 05:59 AM - Post#2751348
I agree. The car should not act as you describe with a proper stock steering/suspension, nor a modified system such as yours.
In my opinion, if the dampener does anything positive , it is covering up some flaw in material, workmanship, adjustment/alignment, or any combination of those.
Pete
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
11-16-18 05:47 AM - Post#2751529
So we did a thorough shake down 3 times, checked calipers, wheel bearings, spindle arms found nothing. All I can say at this point is that the stabilizer works great. Ill be checking the front rnd out regularly in hopes to find a flaw.
Me
DonSSDD
DonSSDD
Reg: 08-21-01
11-16-18 06:47 AM - Post#2751535
The 63 corvette, manual steering, had a steering damper.
Your issue may have something to do with your 605 setup, they can be hard to get working right and can have "bump steer" issues, whatever that is. I got rid of the 605 (it was a leaky old setup) on my car and went to completely stock. My 605 was really "twitchy" and sensitive, likely a bit too much boost. I had to keep both hands on the wheel at all times. My stock setup will track fine with no hands on the wheel.
Lots run the 605 and are happy with it, just search on ChevyTalk on this forum and the 61-64 forum, for 605 and you'll get lots of hits on issues.
Member #2194
stanski
Reg: 05-05-16
11-16-18 07:54 AM - Post#2751539
On my 58 I was plagued with scary steering since day 1 which was 20 years ago. I did go the damper route, which helped, but still never satisfied. Last try was a 605 box which made a big difference and then upped my game with a low flow valve in the pump and now I have the steering feel I've always wanted.
rhttps://www.speedwaymotors.com/Mustang-II-Power-S...
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
11-16-18 11:00 AM - Post#2751546
The Borgeson box REQUIRES (their instructions say 'recommended') approx +4 degrees of caster. Which is why one NEEDS the new upper control arms (GW part number CTA 84a has +5 built in). Don't know what your car has been aligned to, but if the goal was to approach the original/stock basically 'neutral' caster, that would aggravate (if not cause) steering 'wander'.
Also, the integral Borgeson is 14:1 ratio (as I remember; maybe its 16:1?) while the stock power box is something like 22:1 and has no hydraulic pressure within it. The result is the steering w/the integral Borgeson box can get quite 'twitchy'. A pressure regulator like the Borgeson part #899001 can provide adjustment of the pressure and reduce the 'twitch'. The process of getting the pressure 'right' is trial and error (if there is a better way, I would very much appreciate knowing what it is).
If the 'new' universals in the steering column are not 'phased' properly, that can cause problems.
Don't know what springs/shocks you have nor their condition.
A 'large' sway bar such as Global West SB5864G reduces roll which will be helpful. That particular bar installs very easily and does not interfere with any other 'stuff'. There are other alternatives.
Just a few pieces of info for your consideration.
Hope this is helpful.
Pete
threeimpalas
Loc: Central Iowa
Reg: 02-21-02
11-30-18 11:32 AM - Post#2752915
You're also using an LS-engine. Which power steering pump are you using in conjunction with the 605 box? Some LS power steering pumps were originally used with rack and pinions, not the traditional steering box. This can result in an output pressure that's different than what you need and erratic steering response.
'58-62s and 348/409s
Execution time: 0.069 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:35 AM
