Username Post: U-joints... can I get it apart?        (Topic#353829)
Bill K.b
Loc: upstate NY
Reg: 10-24-05
11-09-18 07:41 AM - Post#2750873
My 2002 Express 3500 has a bad shake at speed that seems to be the U-joints. It kind of comes and goes at 65-ish but if I take it out of gear and let it coast I can still feel it.
What are the odds I'm going to break bolts off at the yoke trying to change at least that one? That was what happened to my old '89 Suburban; the holes went all the way through and let salt, etc. get into the threads. I haven't crawled far enough under this one to see what it looks like yet.
If one snaps off it means probably buy another yoke, even at $150 or so it's better than the labor to try to drill out the broken bolt and not kill the threads inside.
This has a carrier and 2-piece shaft, so I'll have to figure out how that even comes apart.
The pinion seal is leaking too but I don't think I can fix that myself, no way to get enough leverage on that big bolt without putting it on a lift. So if I know it's going to break stuff I will have to have it farmed out.
It annoys me though that $25 of parts may turn into $175 of parts plus paying someone for several hours labor.
Because this side has more traffic and the vans are still the older style mechanically up to 2002 I thought I'd ask here.
Those who can, do. Those who can't, criticize it on the internet.
Driving 2002 Express 2500
2002 Express 2500 extended
1988 G20 conversion
1993 GMC 3500 dually
Plus cars for swap and sale
& yes, I once tried a frame swap on a 51 Chevy.
454cid
Loc: West Michigan
Reg: 02-18-12
11-09-18 09:35 AM - Post#2750890
    In response to Bill K.b
I don't know... I've had mine off once and had no problem, but that was many miles and years ago. I would start spraying it down with something now, and for the next few days.
Is the center bearing bad? Is it going to get replaced? If not, don't take it apart. If you do take it apart make sure the two halves go back together in the same orientation. They got balanced together.
99 K3500 RCLB
11-09-18 10:04 AM - Post#2750892
Tap the bolts lightly to shock the rust loose. And as mentioned, mark the shaft position to the center support, important to get that back in exactly where it was oe.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
11-09-18 06:39 PM - Post#2750937
wow you sound just like me when I am getting ready to touch anything under our NY vehicles.
Makes things take alot longer than they need to.
Spray them down good. Tap the bolts and straps to help to dislodge surface rust and cross your fingers.
Old School GM fan FOREVER
Bill K.b
Loc: upstate NY
Reg: 10-24-05
11-09-18 11:03 PM - Post#2750958
    In response to rockfangd
If the bolts go into holes that are blind, closed at the other end, then I think it would come apart okay. This thing is rusted in some strange places but most of it isn't terrible.
For what all those parts cost I probably should do both joints and the carrier, none of them are very expensive.
But I also can say screw it and do nothing, I bought another 2002, a 2500, and so long as it drives home for me okay I will start running that and sell this one.
As I think on it, it seems to me I did U-joints on the '95 G30 I had for a year and that one did come apart okay. I think it's the same rearend as this, a 14 bolt semi-floater, at least Rock Auto says the yoke could be the same.
1988 G20 conversion
454cid
Loc: West Michigan
Reg: 02-18-12
11-10-18 11:03 AM - Post#2750998
Really, only a semi-floating axle in a 1-ton?
99 K3500 RCLB
Edited by 454cid on 11-10-18 11:03 AM. Reason for edit: No reason given.
Bill K.b
Loc: upstate NY
Reg: 10-24-05
11-11-18 01:12 AM - Post#2751039
    In response to 454cid
It's a van, they're all that way.
It decided to spring a leak from a trans line and in checking it out I found some frame rot, so spending any more money on it than to keep it going another week or two is probably moot. I'd have to hide or repair the damage to get it inspected again.
I'm kind of mad, I bought another 02 last week and this week the county here local has two up for bid - one with 38,000 miles and one with 30,000 miles. Same lower body rust and both stripper work vans, but at that odometer reading the engine and trans will far outlast the body and chassis.
1988 G20 conversion
Execution time: 0.154 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:58 PM
