Username Post: Fuel starved?        (Topic#353828)
C10KLee
C10KLee
Loc: NC
Reg: 10-14-07
11-09-18 03:07 AM - Post#2750855
Acted like it was running out. Smell gas under hood, but no visible leaks. Changed filter and cleaned carb. Slightly better, but...still acts like it needs more fuel. Vacuum guage reads lower than the usual 18", also. Came back up a bit after the described work. Pump? Trash in bowl? Pulled a plug from each bank and they look good. Times are tough and it's my daily driver again. Cost me work yesterday, though. First time she's left me stranded in memory.
11-09-18 06:34 AM - Post#2750866
    In response to C10KLee
Look for cracked or leaking fuel lines for starters. If it has a Quadrajet, they have a fuel filter in the inlet fitting.
C10KLee
C10KLee
Loc: NC
Reg: 10-14-07
11-10-18 10:50 AM - Post#2750987
Fuel lines look good. Has an Edelbrock. Thinking there may be debris inside. Spraying carb cleaner in the driver's side primary produced the expected bog, but no effect on passenger side. May have to remove top and clean out the bowls? Or, is there a chance the distributor could cause this? Someone mentioned the pickup coil.
Senior Chevytalk Moderator
11-12-18 07:08 AM - Post#2751139
You can ohm out the coil. You'll need a digital voltmeter. I'll have to dig up the values.
C10KLee
C10KLee
Loc: NC
Reg: 10-14-07
11-12-18 03:51 PM - Post#2751182
I think it is the distibutor. Acts like the advance weights are sticking and not returning to base timing at idle. Saw some white grease on the weights and tried a quick fix at work with some contact cleaner. Meh. It's a junkyard part, anyway. Need a new one. Recommendations for best part/lowest cost?
11-13-18 05:15 AM - Post#2751224
A new distributor from Advance Auto or other parts store will work fine on a stock engine. Check with RockAuto too.
C10KLee
C10KLee
Loc: NC
Reg: 10-14-07
11-26-18 03:22 PM - Post#2752445
Put in a new HEI yesterday. Better, but still a miss off idle. Saw a corroded terminal on the old cap (#4), so I'm gonna look at the plugs/wires next.
Execution time: 0.055 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:09 AM
