Username Post: How To Remove Air Filter Box '97 Tahoe        (Topic#353823)
buns
buns
Loc: Upper Left Coast
Reg: 06-12-06
11-08-18 08:33 PM - Post#2750840
Trying to remove the box to gain access to the leaking heater water shut off valve. I removed the bolt in the inner fender, but still having trouble. I pushed, pulled and twisted. Nothing happening. I'm sure it's quite simple when you no how.
Keith Seymore
Keith Seymore
Loc: Southeast Michigan
Reg: 09-17-08
11-09-18 06:28 AM - Post#2750864
    In response to buns
You are correct (it's pretty easy).
It's all snap fit, so once you remove the bolt you should be able to jiggle everything apart.
Failing that you might try opening the air cleaner box and slipping it out from underneath the inlet, leaving the inlet snapped into the fender.
The plastic is fairly flexible so I think you can be rough without worrying about breaking it.
K
Chevelle Intro: http://www.popularhotrodding.com/features/1005phr_...
My Pontiacs: http://forums.maxperformanceinc.com/forums/showthr...
Pickup: http://67-72chevytrucks.com/vboard/showthread.php?...
Edited by Keith Seymore on 11-09-18 06:30 AM. Reason for edit: No reason given.
454cid
Loc: West Michigan
Reg: 02-18-12
11-09-18 10:26 AM - Post#2750889
    In response to buns
I don't have any bolts holding my airbox in place. I have the Delphi, not the Donaldson box, Though. Still I didn't think there was a bolt. It's a plastic push pin thing. You just disconnect the intake boots and pull up and maybe slide right.
Trucks don't have the valve. Is it attached to the inner fender?
99 K3500 RCLB
buns
buns
Reg: 06-12-06
11-09-18 12:14 PM - Post#2750896
    In response to 454cid
The valve is inline (floating) with the heater hoses, about 8" from the firewall, controlled by vacuum. I believe it is only used with air conditioning.
https://www.napaonline.com/en/p/BK_6601293
buns
buns
Reg: 06-12-06
11-09-18 07:29 PM - Post#2750936
    In response to buns
Leaky valve:
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
11-10-18 03:42 AM - Post#2750960
    In response to buns
That isn't original. Someone has added that.
Jeff
'88 Chevy K3500, aluminum head roller cam 511inĀ³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
Senior Moderator
11-10-18 05:56 AM - Post#2750964
    In response to bowtie44s
He didn't mention it but he has a Yukon. Those pieces are on the SUV's with rear heat, IIRC.
Execution time: 0.102 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:57 PM
