Username Post: Oil filter spring location?        (Topic#353818)
Beltfed
Reg: 10-04-18
11-08-18 05:03 PM - Post#2750810
I changed the oil and oil filter before trying to start engine after 30+ years of sitting. I can’t figure out the correct way to install new filter. I have a spring and odd shaped spacer that doesn’t appear in the factory assembly manual. Don’t know it the spring and spacer go at top or bottom of filter or if they are necessary. The old filter was shorter than the one I purchased. Thanks
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
11-08-18 05:55 PM - Post#2750816
    In response to Beltfed
what are we working on?
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
Beltfed
Reg: 10-04-18
11-08-18 06:17 PM - Post#2750821
    In response to 62chevy427
Sorry, 1957 283ci.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-08-18 06:50 PM - Post#2750825
The spring sits on the bottom of the filter, flat thing to filter.
The oil filter element is too short because it is for a 1958 and up.
The 1956-1957 took a 131 and the 1958 and up a 141 AC.
Beltfed
Reg: 10-04-18
11-08-18 08:49 PM - Post#2750842
    In response to Gene_Schneider
The old filter I removed was about 1/2” or so shorter than the new one I installed. So this spring is to be used on the correct length canister filter? My other question is how the heck does the canister housing seal at the bottom hole for the bolt. The spring would hold the canister off the bottom and other than a copper washer at the bolt head I see no seal or gasket of any kind.
Edited by Beltfed on 11-08-18 08:50 PM. Reason for edit: No reason given.
Beltfed
Reg: 10-04-18
11-09-18 05:16 PM - Post#2750924
I installed the filter as directed above. I used a “Wix” #51123 as an AC was unavailable. Data for filters indicate only a very small difference in height. Thanks for the help.
Execution time: 0.062 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:20 AM
