Username Post: Will it fit?        (Topic#353812)
Jonzin
Reg: 05-13-16
11-08-18 11:38 AM - Post#2750777
I have a 1983 Scottsdale 4X4
I just acquired a 454 stroked to a 496 big block with a B&M blower. My question is will it bolt up to my 350 turbo trans and is there motor mounts made that will let me install this big block in this truck.
1951 Styleline Deluxe 235 3 speed
1967 Manix Dune Buggy
1982 Corvette
1999 Honda Valkyrie
2000 Chevy Truck 4X4
2008 Corvette "Z"
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
11-08-18 12:34 PM - Post#2750784
    In response to Jonzin
Welcome to the site.
1974 Cheyenne 10 LWB 350/TH350/AC/4 BBL Quadrajet
100 CHEVY
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
11-08-18 05:38 PM - Post#2750811
Welcome to Chevy Talk!
It should bolt up to your 350.
If your truck was a bigblock originally,it will fit.
If it was a smallblock originally,you'll need to find the big block clam shells.They are about 3/8" higher than the small block clam shells.
If you try to use the small block clam shells,your big block fuel pump will sit on the crossmember.
If it's fuel injection or remote electric fuel pump,either mount will work.
Mike.
Edited by 100 CHEVY on 11-08-18 05:40 PM. Reason for edit: No reason given.
kzhurley
kzhurley
Loc: Millersburg,Ohio
Reg: 01-02-12
11-28-18 09:22 PM - Post#2752741
    In response to 100 CHEVY
Also with smallblock mounts,fan may hit the fan shroud. Jad this happen on my sbc to BBC swap.
1950 Styleline Deluxe 2-door sedan..
348 tripower/NP833 4-Speed/3.73
1950 Styleline Deluxe 4-door..
Vortec 4200 I-6/4l60e/3.42/current project car
1956 Cadillac Coupe de Ville 500 efi/4l80e
1987 GMC R1500 Sierra Classic
454 tbi/700r4/3.42
Senior Chevytalk Moderator
11-29-18 06:53 PM - Post#2752836
    In response to kzhurley
Wow!! Upgrade the motor and transmission mounts to polygraphite. The mounts are stronger than stock and will help put the power down. Eventually, the 350th trans will need upgrading. What is you planned torque converter stall?
Execution time: 0.118 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:15 PM
