Username Post: Is a 468 bored .30 over?        (Topic#353800)
79eliminator
Reg: 10-25-18
11-07-18 07:20 PM - Post#2750713
I might build a 468 out of my 454. Are they bored 30 over or 60 over?
1979 eliminator speed boat
11-07-18 08:58 PM - Post#2750729
    In response to 79eliminator
It's .060" over.
79eliminator
Reg: 10-25-18
11-07-18 09:19 PM - Post#2750734
    In response to Rick_L
Ok thanks. My block might need bored so I might as well go big.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-08-18 06:50 AM - Post#2750745
displacement formula
bore x bore x stroke x number of cylinders x .7854
examples
4.030 x 4.030 x 3.75 x 8 x .7854= 383
4.31 x 4.31 x .4.0 x 8 x .7854= 466.8
Edited by grumpyvette on 11-08-18 07:28 AM. Reason for edit: No reason given.
79eliminator
Reg: 10-25-18
11-08-18 07:10 AM - Post#2750747
    In response to grumpyvette
Got to thinking. Who makes a 496 kit?? That might be an idea also. I’ve seen on eBay there’s a kit or two but don’t know what they are like. They come with a crank or can I have the machine shop turn mine to work.
454cid
Loc: West Michigan
Reg: 02-18-12
11-08-18 09:33 AM - Post#2750757
Only if you want to use your block up all at once. I would bore it as little as possible. Boring is not a good way to get more displacement. You don't get enough to make a difference. If you want more displacement you'll want to stroke it.
99 K3500 RCLB
79eliminator
Reg: 10-25-18
11-08-18 10:46 AM - Post#2750769
    In response to 454cid
Ok, I’m all ears. What’s the minimum I can bore it and still stroke it??
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-08-18 11:29 AM - Post#2750775
.03 over is generally considered a standard over bore size and fitting a 4.25" stroke crank is not difficult
reading the links and sub-links helps
Edited by grumpyvette on 11-08-18 11:34 AM. Reason for edit: No reason given.
454cid
Loc: West Michigan
Reg: 02-18-12
11-08-18 12:36 PM - Post#2750785
The minimum you can bore is whatever amount cleans up the bore and find piston/rings... it depends on the condition of your engine, and parts availability.
Edit: Usually people go .030", as Grumpy said. I'd guess that's probably due to part's availability.
It's got nothing to do with the stroke.
99 K3500 RCLB
Edited by 454cid on 11-08-18 12:40 PM. Reason for edit: No reason given.
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
11-08-18 08:24 PM - Post#2750838
I used a Scat 496 kit, includes crank, rods, pistons, bearings.
Scat list a 489 kit - the 496 is the same part number but 030" over. The part number for mine was 1-91510BI-030
I went for the cast crank which is good up to about 700 hp I think.
Steve
1966 Caprice 396 496 496mkII TH400
Edited by Crusty66 on 11-08-18 08:31 PM. Reason for edit: No reason given.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-09-18 09:09 AM - Post#2750876
    In response to Crusty66
before you buy components talk to both the vendors and your machine shop of choice , you damn sure don,t want mis-matched components and clearances.
you need to measure accurately, know what your current block will function correctly with and pay attention to clearances and other details that make or break the engines potential durability and power potential.
Execution time: 0.084 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:51 PM
