Username Post: gas shut-off valve        (Topic#353799)
arnie
Reg: 08-26-18
11-07-18 06:15 PM - Post#2750709
The gas shut-off valve at the tank outlet on my 1937 Chevy car appears to have a slight leak.
I checked with Chevys of the 40s for a replacement and they only list a shut-off valve that connects the tank to the intermediate fuel line for a '49 to '54 truck that comes with a 3/8" threaded pipe that connects into the bottom of the tank.
Does anyone know the connection size on a stock 1937 Chevy? I don't want to take the old shut-off valve off until I know that I have the correct replacement parts.
Chevs of the 40s
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-07-18 08:50 PM - Post#2750727
    In response to arnie
The only 1937 car to have a shut-off valve is the business coupe due to the location of the tank.
It is 2 11/16" long,1/8" pipe and 1/2 - 24 threads, fit 1937-1939 coupes and sedandelivery.
arnie
Reg: 08-26-18
11-09-18 11:07 AM - Post#2750893
    In response to Gene_Schneider
Gene, That's most helpful. Do you know where I can purchase a replacement shut-off valve or can I just eliminate it?
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
12-04-18 07:57 AM - Post#2753309
Have you tried to tighten the packing nut?
Cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
arnie
Reg: 08-26-18
12-06-18 05:29 PM - Post#2753666
    In response to Rustchips
Thanks, it's worth a try.
38TownSd
Loc: Bracebridge Ontario Canad...
Reg: 04-04-13
12-15-18 01:44 PM - Post#2754602
My 1951 GMC (Canadian) 1 Ton has a similar shutoff on the bottom of the tank. The vendors that offer parts for those trucks sell the shut off valves.
arnie
Reg: 08-26-18
12-16-18 05:06 PM - Post#2754724
    In response to 38TownSd
Gene, 1/8" pipe from the tank seems rather small. I tried measuring the line with my calipers and it seems to be much larger. Where did you get your information?
Rustchips,I tried tightening the packing nut and that seemed to have stopped the leak however the opening in the floor where the fuel line goes up into the tank ( the tank is above the floor) seems like it could still be moist. I will continue to monitor it.
38TownSd,Chevys of the 40's was the only supplier of a shut-off valve that I was able to find and they tell me it doesn't fit a '37 coupe, only
'49-'53 trucks.
1971BB427
1971BB427
Loc: Portland,Or
Reg: 12-06-09
05-01-19 08:24 AM - Post#2765471
1/8" pipe fittings are actually pretty large. They measure .407" OD, which is plenty of ID for stock fuel draw. Too small for a V8 that sucks more fuel.
1969 Suburban 2wd 350
1939 Chevy passenger coupe
1946 Austin gasser 327/TH350
http://img.photobucket.com/albums/v691/marlinguy /D...
http://www.hunt101.com/data/500/medium/DSCF3 906.JP...
Chevs of the 40s
Execution time: 0.11 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:26 PM
