Username Post: Modifying 1954 Chevy Powerglide shift detent        (Topic#353796)
100fires
100fires
Loc: Santa Fe Springs, Ca
Reg: 04-15-15
11-07-18 09:16 AM - Post#2750670
Has anyone modified the shift detent to work with a 700r4? I know they sell replacement for the Tri-Fives. I trying to make it work with the column shifter.
Any input would be appreciated.
Chevs of the 40s
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
11-07-18 11:07 AM - Post#2750677
    In response to 100fires
Try LimeWorksSpeedShop.Com. They do sell a universal setup that clamps around the sheering column. Not sure how it would work though with the "separate", exposed, shifter shaft. Member drew1987 made his own detent for his 50 with a TH350; should be able to find it in his build sheet.
I am Butch/56sedandelivery.
Edited by 56sedandelivery on 11-07-18 11:11 AM. Reason for edit: No reason given.
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
11-07-18 02:15 PM - Post#2750689
If you decide not to use the original shifter, you may want to consider an Ididit column. I am using a column shift Ididit in my '53 Belair with a Lokar shifter linkage kit for my 700-R4.
Vern
Attachment: 1959_Corvette_Steering_Wheel1.JPG (2.72 MB) 2 View(s)
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, Vintage Air, EZ Wire, Ididit column, Cruise/Tilt, 59 Vette Steering Wheel, 4-Wheel Disc Brakes, Posies Springs, Coker Radials, Nova 10-bolt, Mustang II front, Continental Kit
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
11-08-18 06:08 AM - Post#2750746
I am not sure how the original looks, but I built my own for a modified manual shift column. The detect was basically a plate that was solid on on reverse and 2-1 so the shifter can move without being pulled toward me from R through N and into D, and could go back up to N, but because R and 2-1 are solid, the shifter would have to be pulled back toward me to get into either gear. The result feels identical to a 2010 impala or something else thats modern. It has been used by non-car people from 20 years to 80 years old and they didn't ask, nor did I tell them how to shift or where the gears were, which is what I was going for... natural. The design for a 700r4 vs my th300 would just be a longer plate. I can did up photos or make a video if you want more info on this
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
Edited by drew1987 on 11-08-18 06:08 AM. Reason for edit: No reason given.
Chevs of the 40s
Execution time: 0.096 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:38 PM
