Username Post: Original Valve Cover Question???        (Topic#353793)
Willow
Reg: 05-25-12
11-06-18 09:26 PM - Post#2750648
Greetings All:
On our 1984 Corvette, Original engine, the original valve covers are cast aluminum. The New Fel-Pro Perma Dry gaskets came with metal spreaders for under the bolts.Due to shape of covers, unable to use the spreaders because casting raises bolts up a bit off the actual surface of the valve cover. Since we are switching over to studs instead of bolts for cover, will this non use of spreaders be an issue? Also, Fel-Pro states install gaskets DRY, no sealant of any kind.
As always, Thanks in advance for your help.
Regards: Willow
scrambldcj8
scrambldcj8
Loc: MA
Reg: 04-06-03
11-07-18 04:45 AM - Post#2750658
    In response to Willow
Shouldn't have an issue. The original cast valve cover didn't use spreaders so you shouldn't need them now, studs or bolts. Cast covers are generally more rigid than say stamped steel covers...where the spreaders may be needed depending on thickness of the material used.
Willow
Reg: 05-25-12
11-07-18 08:58 AM - Post#2750668
    In response to scrambldcj8
Thanks, appreciate your reply.👍
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
11-07-18 09:16 AM - Post#2750671
I ALWAYS! glue the valve cover gaskets to the cover on a small block. If they ever start to leak, which they all do after years of service, they are much easier to scrape off of the valve covers than the head.
I do recommend silicone on this application. Just make sure your silicone is completely dry before you install the covers.
If you put them on wet, it lubricates the surface, and makes it slide out. It always slides out in the back where you can't get to it.
Just my two pennies. Feel free to ignore.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
11-07-18 08:00 PM - Post#2750730
    In response to beagrizzly
Better yet on a cast valve cover, use contact cement. No need to wait on silicone to set up. The contact cement sets right now.
454cid
Loc: West Michigan
Reg: 02-18-12
11-08-18 08:34 AM - Post#2750758
    In response to Rick_L
Is anything necessary? I know when I'm replacing something the last thing I want to do is struggle to get old gasket off of some surface.
99 K3500 RCLB
YOUNG57
Loc: Tennessee
Reg: 12-06-10
11-08-18 09:52 AM - Post#2750770
If "Fel-Pro states install gaskets DRY, no sealant of any kind." I would believe them and install them DRY with no sealant of any kind.
Always worked for me.
Execution time: 0.168 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:21 PM
