Username Post: 2008 Colorado - Rewire Accessories Outlets        (Topic#353786)
goofyfish
Loc: Frederick, MD
Reg: 02-25-05
11-06-18 05:32 AM - Post#2750583
Hi all...
I need to change the wiring for the two accessory outlets so they will lose power when the ignition is turned off. Both stay hot at the moment; the radio stays on until a door is opened. What is the best location to tap?
'95 K1500 4X4 Ext. Cab, 5.7L, 4L60E - Stock From Top To Bottom
217K - 3.73 Ltd Slip Rear - HD Tranny & Oil Coolers
'02 K1500 4X4 Ext. Cab 103K
'08 Colorado 53K
'95 Yamaha FX1 Superjet
'02 23' Bayliner Rendezvous
'04 Yamaha GP 800
Senior Chevytalk Moderator
11-06-18 05:38 AM - Post#2750587
    In response to goofyfish
It may not be possible. Most functions are now ECM controlled. Options have to be programmed off. Do you have a wiring diagram? Does the owners manual have an option to turn it off? What's the other accessory temporarily on? You can wire it to a relay and fuse box ignition option.
goofyfish
Loc: Frederick, MD
Reg: 02-25-05
11-07-18 06:03 AM - Post#2750660
No diagram. Nothing in the owner's manual that shows the ports can be reconfigured. The only thing that stays on when the ignition is switched off is the radio, which goes off when the door is opened.
'08 Colorado 53K
'04 Yamaha GP 800
11-07-18 06:44 AM - Post#2750661
Ok, it's probably ECM controlled. My Dodge Nitro has the same option. The radio stays on until it times out (usually 1 min) or a door is opened. Mine has a TIPM (totally intergrated power module). I'm not familiar with GM same version.
Do you mean the radio stays on all the time?
I found some quick info: Go to Post #20.
https://www.coloradofans.com/forums/61-general-tru ...
A simple fix might be the door jam switch. Check it.
Edited by gchemist on 11-07-18 06:48 AM. Reason for edit: No reason given.
goofyfish
Loc: Frederick, MD
Reg: 02-25-05
11-18-18 08:54 AM - Post#2751695
Sorry for the delay, life interferes sometime. Not sure what you mean by checking the jam switch.
'08 Colorado 53K
'04 Yamaha GP 800
11-18-18 10:42 AM - Post#2751703
Somewhere along the door/body is a switch like this one: https://www.ebay.com/itm/2-Chevy-GMC-Humme r-H3-Col...
goofyfish
Loc: Frederick, MD
Reg: 02-25-05
11-18-18 07:23 PM - Post#2751725
Sorry, I get where and what it is, but not what I am checking it for. The cab light functions on/off and the RAP for the radio deactivates when the door is open.
'08 Colorado 53K
'04 Yamaha GP 800
Execution time: 0.107 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:21 PM
