Username Post: 3 link or 4 link suspension        (Topic#353784)
Harlyd
Loc: Macomb MICHIGAN
Reg: 08-13-18
11-05-18 11:47 PM - Post#2750573
Hi guys, I have a 62 Impala with a 327 4 speed and a 3.55 rearend. I’m replacing the upper and lower control arms as the old ones are worn and It’s a little loose in the rearend under heavy acceleration. The motor is pushing around 350hp and I was going to order the UMI performance 3 link kit but now I’m debating whether I should spend the extra money and order the 4 link for extra insurance. With these new suspension systems can the three link handle the xtra horsepower or should I bite the bullet and do the four link. Any thoughts would be appreciated.
Tom_Kochtanek
Tom_Kochtanek
Loc: Columbia, Missouri, USA
Reg: 11-19-02
11-07-18 07:29 AM - Post#2750662
    In response to Harlyd
I have a pair of 62s, both now have the 4 link setup in an otherwise stock setup. Both are dual quad 409s, quite a bit of torque goes to the rear end. One is a 3.36 posi in a driver car, the other 4.56 BOP rear end in a drag car.
So I have a bit of a bias, I suspect!
Tom Kochtanek
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
11-07-18 09:07 AM - Post#2750667
For a 327 motor you should not need a UMI arms(I am talking about adjustable UMI arms). I have 2 62's with original upper control arms and one with 2 adjustable upper UMI arms. The one with adjustable upper UMI arms is a 409 engine with 475 HP and a Richmond 5 speed
Just use two original upper arms.
Add an additional original upper arm and brackets to the drivers side in addition to existing one on the passenger side.
You will have to remove the rear end housing to weld on the new bracket(the bracket is available new) to the rear end housing (see pictures)
Paul
Attachment: P1000443.JPG (922.23 KB) 3 View(s)
Welding on a 2nd upper control arm bracket to the rear end housing
Attachment: P1000444.JPG (935.05 KB) 3 View(s)
Close up of the welding
Attachment: DSCN7673.JPG (174.63 KB) 7 View(s)
Completed installation using a original upper control arm and mounting bracket on the drivers side
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Web http://paulstensland.com/
Harlyd
Reg: 08-13-18
11-12-18 11:01 PM - Post#2751218
    In response to pvs409
Thanks guys for the input. I already have a new upper adjustable control arm, I bought it when I got the lower control arms. I was told the new upper and lower arms should stiffen up the rear enough that I wouldn’t need the other upper arm. But then I heard a lot of conflicting opinions on the subject so I thought I’d pose the question hear and it’s sounding like four link is the way to go. I definitely don’t like how squirley the suspension gets when I get on it!!
Execution time: 0.082 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:49 PM
