Username Post: I spun a bearing in my 1970 impala 350        (Topic#353767)
Chevykrys
Reg: 11-04-18
11-04-18 07:21 PM - Post#2750468
Can someone tell me what i need to do to fix or what is it that made it spun i had the crank checked nd stuff then replaced the bearings nd it started right back
11-05-18 08:41 AM - Post#2750502
    In response to Chevykrys
Welcome to CT. So you spun a rod bearing, no crank or rod damage? Usually this occurs with loss of oil pressure, overreving, general engine fatigue. No way to diagnose this accurately from here, onsite analysis is the only way.
Chevykrys
Reg: 11-04-18
11-05-18 02:58 PM - Post#2750531
Thanks i had it checked ill just take it to someone else this time
GMMark
Reg: 11-23-18
12-15-18 06:38 AM - Post#2754560
Theres no way the crank WASNT damaged, who told you it wasn't?
Also the big end of the rod will need resizing.
When a rod bearing spins, its from lack of oil, it heats up, grabs the rod journal on the crank, then the bearing tangs tear off allowing the bearing to spin in the big end of the rod, eating it, and also chewing on the crank.
12-15-18 06:49 PM - Post#2754621
    In response to GMMark
Seconded!
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
01-04-19 07:31 PM - Post#2756591
MAIN or ROD bearing? There's a BIG difference on how to approach this. A main bearing may mean a different block (cheaper than having it line bored, if it even can be). Rods are cheaper, but still involve a complete tear-down, re-machining, and re-assembly. May be just cheaper to find another complete 350; unless it's a numbers matching car. But even then, these days, there are ways around that. There's really not a cheap way around this. I am Butch/56sedandelivery.
Execution time: 0.085 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:49 PM
