Username Post: power brake booster        (Topic#353766)
ejw71
Loc: Bella Vista, AR
Reg: 01-19-01
11-04-18 07:05 PM - Post#2750466
My 63 rear end ratio is an open 3.24.
Would it be worth the work to install a 3.08 posi, which I already have?
Also, would it require changing the trans speedometer gear? Thanks, Ed
DECEASED
11-09-18 04:01 PM - Post#2750914
    In response to ejw71
A 3.24 ratio was not offered in 1963. Available ratios jumped from 3.08 to 3.36.
IMO the 3.08 would be a worthwhile swap if you want taller gearing and/or posi. If you want the speedo to read accurately you would also need to change the speedo driven gear in the trans.
Execution time: 0.089 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:14 PM
