 Page 2 of 2 <12
Username Post: Winter project        (Topic#353765)
Hards..60
Gold Supporting Member
Hards..60
Loc: Northern Ontario,Canada
Reg: 10-20-07
12-07-18 04:36 PM - Post#2753769
    In response to BigDogSS
  • BigDogSS Said:
FYI, I talked to the owner of http://www.bowtieoverdrives.com/ a while back at a swapmeet, and he said 75% of phone tech support calls are for the TH200-4R transmission vs. 25% for the TH700-R4. And his sales are 80% 700-R4 vs. 20% 200-4R. He says 700-R4 are easier to install/set up, but people want the 200-4R because of the "better" gear ratios, which he says you really can't tell the difference. He recommends the 700-R4, if you decide to go OD.
  • Hards..60 Said:
....Love this site....
Cool! Please consider becoming a Supporting Member!
https://www.chevytalk.org/membership1.html
Done....
Roger.
1960 Impala 2dr hard top - 348 tri
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
12-07-18 05:00 PM - Post#2753772
    In response to Hards..60
Right-on, Roger!! Thanks!!
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
Edited by BigDogSS on 12-07-18 09:21 PM. Reason for edit: No reason given.
Hards..60
Hards..60
Reg: 10-20-07
12-20-18 04:40 PM - Post#2755142
  • raycow Said:
Thank you for taking the time to count the ratio and post it.
Now just to stir the pot a little more, here is what GM thinks you should have in there.
http://chevy.oldcarmanualproject.com/shop/1959_60/...
So is GM wrong, or did they just fail to mention that a buyer could order an optional ratio If it's a gear they already have sitting on the shelf, the cost would have been minimal, perhaps even free.
I'm going with GM is wrong
Ok so here's what I've done so far.
Also took some picture of starter holes that some have brought up.
If I counted the number of teeth on the flywheel, properly then I have 167.
The overall length of the transmission is around 125", including a 5" tail shaft.
Now I realise I will need to do something about the torque lock-up so between the 700r4 and the 200 4r is one easier than the other?
Attachment: HPIM1092.JPG (1.67 MB) 9 View(s)
Attachment: HPIM1097.JPG (1.74 MB) 9 View(s)
Attachment: HPIM1105.JPG (1.77 MB) 11 View(s)
Roger.
Hards..60
Hards..60
Reg: 10-20-07
12-22-18 02:59 PM - Post#2755304
Could someone answer something for me about the governor on a power glide.
I've taken pictures of the governor itself and some information from the 58 shop manual.
It seems like there's suppose to be a gap at the top and bottom of the valve. If you look closely there doesn't seem to a gap at the bottom and the one at the top measures 35 thousands of inch.
Can someone explain how this governor works besides the fact that it controls pressure. It seems to me that there should be a flow from top to bottom...other than that I'm lost
Attachment: HPIM1116.JPG (1.56 MB) 9 View(s)
Attachment: HPIM1117.JPG (1.37 MB) 5 View(s)
Attachment: HPIM1114.JPG (1.46 MB) 9 View(s)
Attachment: HPIM1112.JPG (1.32 MB) 9 View(s)
Bottom of governor valve...no visible gap.
Roger.
Hards..60
Hards..60
Reg: 10-20-07
01-03-19 04:21 PM - Post#2756494
Figured out how governor valve works. It was stuck so I cleaned it and now it's good. I did find some dicolouration though as if it got hot...
I also discovered the throttle valve is broken..
Found sludge and dirt...
Also found the pin that drives the rear pump was broken and messed things up in there pretty good..
Attachment: HPIM1124.JPG (1.22 MB) 9 View(s)
Attachment: HPIM1139.JPG (1.7 MB) 9 View(s)
broken throttle valve lever
Attachment: HPIM1121.JPG (1.79 MB) 9 View(s)
sludge..dirt
Attachment: HPIM1140.JPG (3.25 MB) 9 View(s)
crusty...
Attachment: HPIM1213.JPG (1.44 MB) 9 View(s)
broken pin..
Roger.
Hards..60
Hards..60
Reg: 10-20-07
01-03-19 04:32 PM - Post#2756496
Ran out of room....
Here's what the rear gear pump driven gear now looks like.
It's a wonder the darn thing ran at all..... and I paid for that...
Attachment: HPIM1219.JPG (1.88 MB) 9 View(s)
nicely chewed up
Attachment: HPIM1224.JPG (1.72 MB) 9 View(s)
this is the gear
Roger.
Chair City
Chair City
Loc: Thomasville, NC USA
Reg: 01-24-04
01-03-19 07:19 PM - Post#2756516
Ouch! The drive pin is fairly easy to find. The shaft looks like it may needs repair though. Maybe weld it up and re-drill. Might find the pump on eBay
1960 Impala Spt. Cpe. Now in my son's garage
Hards..60
Hards..60
Reg: 10-20-07
03-17-19 08:57 AM - Post#2762293
    In response to Chair City
Hello gentlemen, I'm back but this time I'd like to ask if someone can help me with a 200-4r.
I think that this is the transmission I'm going to go with since this one doesn't require any cutting of anything.
American Autowire sells a non-computerized lock-up switch kit for a 200-4r that automatically allows the torque lock-up to occur without any special requirements other than a 3/8 NPT threaded 4th gear pressure port on the transmission.
My question is would someone have a picture of a 200-4r that shows where and what this pressure port looks like? It doesn't have to be an actual transmission but maybe something out of a shop manual. Also for American Autowire to suggest this port must mean there are some 200-4r's that have this port and some that don't....I would be curious about what year the one's with the port were made.
Thanks for your time guys.
Roger.
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
03-18-19 06:30 AM - Post#2762347
Hey Roger, I have been looking for a powerglide forum to ask a question concerning the slipping of mine from low to drive and I checked a little about your question and found quit a lot and here are three that you could look at two of them have contact information that you could call or email, but this may not be what you are looking for. Hope this will help, Lamar
https://gearstar.com/blog/details/200-4r-t ransmiss...
https://gbodyforum.com/attachments/lockup-ki t-jpg....
https://www.corvetteforum.com/forums/c3-general/22...
Hards..60
Hards..60
Reg: 10-20-07
03-18-19 07:04 AM - Post#2762351
    In response to PLS
LAMAR!!!!!
You are the best....that's exactly what I was looking for.
Thanks a bunch my friend....or maybe BFF
Roger.
PLS
PLS
Reg: 06-07-12
03-18-19 04:40 PM - Post#2762418
Thank you Roger since I am usually on the receiving end of help I'm glad when I am able to offer a little help along the way. Keep us posted on how things are going. Lamar
ragtp66
ragtp66
Reg: 12-09-07
03-25-19 10:25 PM - Post#2762919
If you have more questions or need parts on an old glide give David a call at http://www.autotran.us/ he is a wealth of knowledge on these old boat anchors.
I did a swap on a 58 Belair project car from PG to 700R4 easy enough to do. I used the Bowtieoverdrive kit to lock and unlock the torque converter. very detailed kit and they have EXCELLENT customer service even if you did not buy your trans from them. I got pre bent cooler lines made by Schaefer's but sold through Summit Racing and you can get the crossmember from BTO also.
Toys:
1987 Sea Ray Pachanga 22
Hards..60
Hards..60
Reg: 10-20-07
05-10-19 05:22 AM - Post#2766082
  • raycow Said:
  • ragtp66 Said:
.....If you have a bellhousing mounted starter on the 348 you will need to switch to a block mount, the holes SHOULD be already in the block. The 348 flywheel should be fine.....
All of the 348s I have seen were drilled for a block-mounted starter. However, the drilling on a 348 or any other Chevy V-8 made before 1962 will accept ONLY a 168 tooth starter (staggered bolt pattern). If your stock 348 flexplate will bolt to the 700-R4 converter, you should be good to go. If it won't, make sure the flexplate you get for the 700-R4 has 168 teeth and not 153.
Question...Ray....and others...
I have invested in a 1985 to 1988 CZF 200-4r with multi fit bell housing. My flex plate has 168 teeth on it and does not properly fit in side the bell housing of the transmission.
If I read your comment properly it sounds like I will have to invest in a starter and I will need to find a smaller (153 tooth ??) flex plate for clearance.
Would that be correct? Will I have an issue with finding a starter? Right now those are my only two concerns. I think I'll be fine with the rest.
Roger.
05-10-19 07:38 PM - Post#2766150
Roger, sadly raycow passed away. Here is the info on his passing.
29-41, 42-48, 49-54 Moderator
Hards..60
Hards..60
Reg: 10-20-07
05-11-19 06:05 AM - Post#2766165
I'm so sorry.
Don't know how I missed your post.
A wise man he was, in deed...loved his posts.
Roger.
Roger.
 Page 2 of 2 <12
Execution time: 0.097 seconds.   Total Queries: 21   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:38 PM
