Username Post: 1959 Heater Harness        (Topic#353741)
TYTILIDIE
TYTILIDIE
Loc: Colorado Springs
Reg: 10-21-15
11-03-18 06:05 AM - Post#2750323
Will this work for a 59 Belair?
https://www.jegs.com/i/Original-Parts-Grou p/759/02...
It looks like the blower motor connector is a newer style not like the old one. I have an original blower motor. I do not have AC but that's OK if that harness works I'd just tuck the AC part away for a later day.
I can easily build my own harness but the blower motor connector makes it difficult since I am not sure what that style of connector is called. That's the only thing I would be missing if I can't locate a harness.
Me
Edited by TYTILIDIE on 11-03-18 06:11 AM. Reason for edit: No reason given.
Chair City
Chair City
Loc: Thomasville, NC USA
Reg: 01-24-04
11-03-18 12:38 PM - Post#2750345
    In response to TYTILIDIE
It doesn't look like the original connector which is the same as the water temperature sender connector. It uses a Packard 56 series female terminal inside a plastic body with an slot opening in the side. The 56 series terminals are available from Mad Electric.
I have one of the plastic connector bodies. Let me know if you need it.
1960 Impala Spt. Cpe. Now in my son's garage
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
11-03-18 01:56 PM - Post#2750355
Sent you a response on the sale page. No such thing. It was part of the production dash harness and was never serviced as a separate harness.
Donny
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
11-04-18 06:44 AM - Post#2750403
    In response to aawtech
Well that figures. Good to know.
Me
Edited by TYTILIDIE on 11-04-18 06:44 AM. Reason for edit: No reason given.
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
11-04-18 06:46 AM - Post#2750404
    In response to Chair City
So the terminal Im looking for is a Packard 56 series?
Me
Execution time: 0.104 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:30 PM
