Username Post: Which clutch to use        (Topic#353734)
42Special
42Special
Loc: NW
Reg: 09-24-16
11-02-18 01:29 PM - Post#2750274
Question for you guys. I did a mild Hop Up as they used to say when we rebuilt an early 235 babbit pounder for 42. Insert rods bored .020 over 261 cam, dual intake Edmunds manifold w/Carter W1's and Fenton headers. Which clutch would you use the 9" or the 10-3/4" Heavy Duty? I have them both w/correct flywheels. I am tempted to go with the 10 3/4" but wondering if the stock transmission could take the extra mass.
Edited by 42Special on 11-02-18 01:29 PM. Reason for edit: No reason given.
Chevs of the 40s
DECEASED
11-02-18 02:28 PM - Post#2750283
    In response to 42Special
The 9" clutch is marginal for a bone-stock 235. It was used in 235 passenger cars only for 1953 and was replaced the following year by a 10" pressure plate with a 9-1/2" disc in passenger cars and a 10" disc in trucks.
The 10-3/4" clutch was optional through 1953 in passenger cars and 1/2 ton trucks and standard in all larger trucks. It does not create any problems for the stock 3 speed trans. If you have one, I strongly recommend that you use it.
42Special
42Special
Loc: NW
Reg: 09-24-16
11-02-18 03:17 PM - Post#2750289
Thanks Ray! Now the next question. I do have the complete set up, but four of the fingers on the pressure plate, the ends are worn down about 3/16th"s the four are all next to each other. For the life of me I cannot figure out how that would happen. The throwout bearing covers them all. So I don't know if that would be an issue or not
Edited by 42Special on 11-02-18 03:51 PM. Reason for edit: No reason given.
DECEASED
11-03-18 03:22 AM - Post#2750319
I don't know what would cause the fingers to wear like that either. Because of the uneven wear, there is a possibility that the pressure plate might not disengage cleanly, but I don't know any way of finding out for certain without bolting it up and trying it. In case you don't want to take that chance, here is a rebuilt pressure plate on ebay:
https://www.ebay.com/itm/1938-40-41-42-46- 1948-50-...
If the above link doesn't work for you, just go to ebay and enter this item no. in the search box: 123462787767
Please let us know what you end up doing, and here's hoping it goes well for you.
42Special
42Special
Loc: NW
Reg: 09-24-16
11-03-18 03:56 PM - Post#2750364
Thanks Ray I just purchased it! Needless to say I will be going with the 10 3/4" You saved me about $130.00 I was going to call Chevs of the 40's on Monday. Owe you one
DECEASED
11-03-18 05:45 PM - Post#2750370
Happy to help. Please keep us posted on developments as the project moves along.
42Special
42Special
Loc: NW
Reg: 09-24-16
01-09-19 05:40 PM - Post#2756989
Sad to learn of Rays untimely passing. His knowledge and willingness to help everyone will be sorely missed!
RIP Raycow
42Special
42Special
Loc: NW
Reg: 09-24-16
01-09-19 05:40 PM - Post#2756990
Edited by 42Special on 01-09-19 05:42 PM. Reason for edit: No reason given.
Chevs of the 40s
Execution time: 0.066 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:33 AM
