Username Post: 235 mini HEI troubleshooting        (Topic#353722)
Alegm
Alegm
Reg: 01-05-13
11-01-18 09:30 PM - Post#2750226
Hi folks:
in mars this year I bought a Mini HEI kit (incluiding distributor, spark plugs, spark wires set and both square and round coils) from Langdons
I installed the kit following all the instructions(changed the power wire to #10, spark plugs gap close to .060. timing etc) and I used the round coil to start 'cause at this point i had not place where to set the square one. Well the car ran like never before for 1 month or something, i was very happy though, but one day after turn it off and fire it up againg and driving for 2 miles or something the car started to hesitate, jerking and the valves were pinging as if the timimg was wrong..... at some point when I stoped pushing the gas pedal the engine just died and there were not way to fire it up again.(at this point I used my old Delco-Remy points distributor to comeback home).
Next day I tried to restart de egine with the mini HEI again but it didnt worked either... I blamed the round coil and used the old distributor ever since.(at this point i was so disapointed that didnt bother to call Tom and did nothing)
Yesterday i felt enthusiastic again and fabricated a support for the square coil, put in the HEI again, fire it up and ran like crazy for 2 miles or something after wich the same problem came back again. i took the dis. cap out and touched the 4 pins module, it was cold, no apparent problems
Now I know it cant be the coil 'cause i've used both,
what do you guys think may be causing this problems??
Thanks in advance
Alex
ragtp66
ragtp66
Reg: 12-09-07
11-03-18 02:23 PM - Post#2750359
    In response to Alegm
Sounds like a bad ignition module. Even in a large cap HEI they tend to fire up when the engine is cold and then as they heat up they stop. When they finally stop working the car just cranks and wont wire. Did you be sure to use the die-electric grease when you installed it? If the module is a no-name brand that is where I would look. Even with the large cap I keep a spare and a couple screwdrivers in the glove box. If it totally goes out I can swap them and be back on the road again.
Toys:
1987 Sea Ray Pachanga 22
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
11-04-18 07:12 AM - Post#2750407
    In response to ragtp66
I’d suggest a Pertronics, I haven’t had these problems with their module installed in a stock distributor, been using them sine 2002. I’d use their recommended coil.
Member #2194
Edited by DonSSDD on 11-04-18 07:13 AM. Reason for edit: No reason given.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
11-04-18 07:50 AM - Post#2750410
Don't use die-electric grease under the module, use heat sink compound.
Alegm
Alegm
Reg: 01-05-13
11-04-18 04:16 PM - Post#2750454
    In response to 55 Shaker
Yesterday evening/night I started to examine my dist. for 50th time and i discovered what the problem was….. the 6 pointed star was loose(rotate) in its shaft(the piece of the dist. shaft who support the counterweigh advance) ….so that was causing that the timing went crazy…… now I'm figuring out what the solution could be…. do you think I can solder this without affecting the circuit??
DonSSDD
DonSSDD
Reg: 08-21-01
11-05-18 05:33 AM - Post#2750491
Can you post a picture?
Member #2194
ragtp66
ragtp66
Reg: 12-09-07
11-08-18 08:29 PM - Post#2750839
Thanks for the correction ! Brain cramps seem to occur more often the older I get, either that or one to many sockets to the melon when they slip and your on your back. Never understood why they didn't make sockets hex shaped so instead of ALWAYS rolling to the dead center of the car 1" farther then your fingers can reach, they would just stop when they hit the ground.
Toys:
Execution time: 0.093 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:26 PM
