TR56210
Reg: 10-28-18
10-28-18 04:54 PM - Post#2749803
Well a bit of peer pressure had me going from a 350 two bolt main to 383 four bolt main flat tap motor with 600 carb. Now that same dear friend is trying to convince me there is no need to connect the electric choke and that I will learn to cold start this motor. I have two weeks before he returns to help fine tune the car and intend to connect the e choke during this time.
Is there any logical reason to not connect the choke?
fuzz1957
Loc: NE IA
10-28-18 06:30 PM - Post#2749809
In response to TR56210
No
10-28-18 06:54 PM - Post#2749810
In response to fuzz1957
I don’t understand why he wouldn’t want you to hook up the choke. The car will be easier to start and run better when the engine is cold and will automatically adjust as the engine warms up. Without it, especially if the choke blade is still in place but not hooked up, it will be hard to start and you will have to constantly play with the throttle to keep it running and may never run well even when warmed up depending on the static position of the choke blade.
1957 Cameo Carrier |
Algoma56
Reg: 03-14-05
10-28-18 10:02 PM - Post#2749827
No logical reason. Hook it up.
IgnitionMan
Reg: 04-15-05
10-29-18 06:06 AM - Post#2749857
People blindly recommend not doing things correctly, like not using a vacuum advance, or not using one right, no choke, other stuff, because they are taught to not do it right, or, they simply do not, or, refuse to understand it.
USE THE CHOKE.
10-29-18 07:11 AM - Post#2749866
If the choke is not hooked up electrically, but, as mentioned, the blade is in place, the engine will start easily but run way too rich as it warms up and idle too fast. The choke not only lets it start easier, it sets the fast idle so that it stays running while warming up, without holding the throttle in a fast idle position.
TR56210
Reg: 10-28-18
10-29-18 10:46 AM - Post#2749889
In response to acardon
Thanks for confirmation of doing what I and we know as the right thing to do.
IgnitionMan
Reg: 04-15-05
10-29-18 05:05 PM - Post#2749937
Do you have the procedure for setting the choke correctly? It isn't hard to do.
TR56210
Reg: 10-28-18
10-30-18 08:11 PM - Post#2750053
In response to IgnitionMan
Well, it has been awhile, so if you wouldn’t mind sharing it I will follow it. And thanks
