Username Post: 2.2 ecotec shifting.        (Topic#353628)
bigdave75
Loc: Vidor, Texas
Reg: 08-13-13
10-27-18 12:54 PM - Post#2749705
Hey fellas I'm David and my problem is with my '09 cobalt. Reverse works fine it's when I shift to drive that it starts slowly thru first and second when it hits 3rd and 4th it flies like an eagle. I just put a new throttle body on because I took the car to a transmission guy and he plugged his snap on scanner to the obd and seen the throttle position sensor was bad. Well being you can't get the sensor by itself I got the throttle body. When he plugged the scanner into the obd the TPS showed a climb and then fell to around 24. Also when I replaced the throttle body I had the positive side of the battery disconnected.im read for c-4 at this point. Thanks bowtie brothers for any advice or information as to help resolve this issue.
95 Yukon stock
98 2500 ext cab lwb
3" body lift
35" nito grappler
20" incubus off road
10-27-18 01:27 PM - Post#2749707
    In response to bigdave75
Confusing post, it dies in 1 st and second?, at the same throttle setting when it feels better in higher gears. Have you had any time for the pcm to relearn its settings, this can happen when disconnecting the battery. When you say the tps dropped to 24, what does that represent, percent of opening? Is this drive by wire!
Execution time: 0.078 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:19 PM
