Username Post: 2010 chevy espress 1500 LS cruise control        (Topic#353618)
ElDiablo
Reg: 07-19-16
10-26-18 08:54 PM - Post#2749648
i just bought a 2010 express 1500 LS 5.3L van today. no power doors, locks or cruise control. my 1990 G20 had all those things. kinda silly. anyway...i really need to add cruise control to it. this is by far the newest and fewest miles vehicle i have ever owned. it's so quiet! driving it home from the lot i found myself speeding a lot cuz i'm not used to the lack of engine noise and no cruise control. anybody ever add CC to a newer express van? is the 2010 1500 LS drive-by-wire or cable throttle? can i buy one of those $300 3rd party CC controllers or the $50 OEM switch and wire it in somehow? thanks
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
10-26-18 08:57 PM - Post#2749650
    In response to ElDiablo
I have.
I feel for you. I have a 2012 that was driven 750 miles a week and no cruise control.
In order to do it you will need the switch that bolts onto the steering wheel. Can be had for cheap.
You will also need the trim attached to the back of the steering wheel. It has the dip where the switch sits.
You will need the harness from the clockspring to the cruise switch and horn button
Steering wheel gets removed. The wiring is present all the way to the clockspring. The clockspring will not need to be changed.
Just the small harness that plugs into it behind the horn button.
Once installed try it out. If it works you are done.
If it does not then you will have to take a trip to your local dealer to have them program it.
I had to, but yours being a 2010 you may get lucky.
Hope this helps
Edit
D1957E is the delco part number for the switch
Old School GM fan FOREVER
Edited by rockfangd on 10-26-18 09:07 PM. Reason for edit: No reason given.
ElDiablo
Reg: 07-19-16
10-27-18 07:26 AM - Post#2749674
    In response to rockfangd
my old g20 has a vacuum powered CC module that sits on top of the engine block. you're saying i won't need to go into the engine bay? it's all in the steering wheel? i'd also appreciate any help in finding locating the trim part online. so far i can only find that switch
Edited by ElDiablo on 10-27-18 07:52 AM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
10-27-18 09:41 AM - Post#2749688
Nothing under the hood. It should be drive by wire.
It works from the bcm.
The trim and small harness would probably be a good used find.
I got a whole wheel with everything when I did mine from ebay.
ElDiablo
Reg: 07-19-16
10-30-18 10:11 AM - Post#2749990
I've got parts coming in the mail and i just watched a YT video of how to remove the airbag. I've never messed around with an airbag before; how finicky are they? Do i really have to disconnect the battery first?
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
10-31-18 06:10 PM - Post#2750123
I recommend that you do.
They are cake to remove, just take your time and get the feel for the tabs.
Hope these pics help.
The harness on the right is the one you need. And the cruise switches go on the left.
If you get the audio ones too they may or may not work. Mine do not. Dealer said they tried but no success
Attachment: 20170407_162340.jpg (60.04 KB) 15 View(s)
Attachment: 20170407_162349.jpg (71.95 KB) 17 View(s)
Attachment: 20170418_073255.jpg (66.04 KB) 16 View(s)
Edited by rockfangd on 10-31-18 06:16 PM. Reason for edit: No reason given.
ElDiablo
Reg: 07-19-16
12-06-18 10:12 PM - Post#2753696
i got all the parts and plugged it in and the lights on the cruise buttons come on, but no cruise function. i've called the 2 closest chevrolet dealerships and they both told me they could try for $120 to program it but had no clue if it would work.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-08-18 08:07 AM - Post#2753841
Figures. Same issue I had. had mine programmed. quick to program. Easy money for them
ElDiablo
Reg: 07-19-16
01-28-19 11:28 AM - Post#2758391
i've hit a dead end. got the buttons, correct wiring harness, found a dealership that told me over the phone they could program it. finally got a day off work that the dealership was open. just went out there and they said they couldn't do it. they tried getting the software from Chevrolet and chevy told them they need fax proof of a new steering wheel, column, cruise buttons and harness and clock spring that i bought. so i guess i won't have cruise control on this van.
thanks for all the help though! i learned a lot in here
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
02-02-19 06:23 PM - Post#2758852
Can you go to a different dealer?
I had no issues.
They did have to go through GM though.
I provided nothing other than the vehicle with the parts I installed
I am sorry you are running into issues. Although I am not all that surprised.
To me they should all come standard with it.
I am honestly pretty persistent so I work pretty hard to get done what I need.
Edited by rockfangd on 02-02-19 06:25 PM. Reason for edit: No reason given.
ElDiablo
Reg: 07-19-16
03-19-19 07:16 PM - Post#2762510
yeah i've talked with the one dealer in my area that even cares enough to try it. they contacted GM for the software and were told i'd need a brand new steering wheel, clock spring and cruise switch/harness. so...like $700....then the dealer told me it's too much hassle and they wouldn't do it.
i'm taking the van to mobile music soon to have them install the rostra kit. oh well. just need CC before a 1500 road trip in june. thanks for all the help guys!
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
03-19-19 07:42 PM - Post#2762511
I am going to have it done on my 2015 Express soon.
I did the same thing as the 2011.
Swapped the wheel with the SWRC controls. The rest is already there other than the fact it needs to be programmed in.
Execution time: 0.105 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:31 PM
