Username Post: MOTOR MOUNTS        (Topic#353614)
vabeach56wagon
vabeach56wagon
Loc: Chesapeake,VA,
Reg: 04-22-02
10-26-18 01:12 PM - Post#2749634
Is there a method or measurement to determine if the correct 302 (Z28) frame and engine mounts were used on this car during the PO's "restoration"?
paul
Original builder of the Gobstomper - '56 210 9 passenger wagon now in other's hands. Current Ride is '69 X33D80 Z28 Camaro
pdq67
Loc: Columbia, MO, USA
Reg: 08-31-02
02-10-19 01:07 PM - Post#2759562
    In response to vabeach56wagon
Try here David Pozzi's great site.
http://pozziracing.com/camaro_engine.htm
And fwiw, I ran my ripped apart OEM 6-banger rubber mounts that were under my 350SS engine by drilling them for a 3/8" Grade-8 bolt and then 45 degree countersinking the close side.
Suckers never came apart again after this little modification.
Also, they are the thinnest if you need a skosh of hood clearance. I bought new ones from Summit for cheap and have them in my bedroom.
pdq67
Execution time: 0.322 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:42 AM
