Username Post: QA1 spring rates LS motor        (Topic#353605)
jgrimmy
jgrimmy
Loc: Fargo, ND
Reg: 05-30-03
10-25-18 02:56 PM - Post#2749555
What spring rate are you guys using for QA1’s on the front with a iron LS1? If remember correctly the LS is about 100# lighter than a average SB.
57Rustbucket.com
Nick P
Nick P
Loc: De Queen, Arkansas
Reg: 10-15-03
11-01-18 12:58 PM - Post#2750177
    In response to jgrimmy
How is the engine bay outfitted? AC, Power Steering, Battery? Are you using stock or tubular upper/lower control arms? I'd consider 400, 425 or 450 for starters. Springs are cheap and easy to change in comparison to stock suspension. What's the weight of the car? Bias F to R?
Execution time: 0.068 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:10 AM
