 Page 3 of 3 « First<123
Username Post: '67 Impala SS Convertible Identification        (Topic#353599)
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
11-13-18 08:38 AM - Post#2751265
    In response to WarrenL
Great info here, Warren. Thanks.
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
df0rster
Reg: 10-25-18
11-13-18 01:16 PM - Post#2751293
Thanks for the info. I wonder what piece of historical info is causing these discrepancies? Just curious if this was the case for another model year (th400 small block combo).
I’d still like to figure out what these mysterious option codes are after the seatbelt code (py) and like to figure out the original engine. But for now it is being build at a big block car since that’s what it had in it when I bought it.
Btw, could that code have anything to do with the rear air shocks? Not sure that would be coded on the trim tag anyway.
WarrenL
WarrenL
Loc: Hebron, ME
Reg: 11-17-04
11-14-18 03:32 PM - Post#2751411
    In response to df0rster
Air shocks wasn't coded on the cowl tag.
I'm not sure where Alan for the month of January from but he told me at the time he didn't have any fullsize data to look at.
df0rster
Reg: 10-25-18
11-28-18 10:39 AM - Post#2752669
    In response to BigDogSS
More info below.
I finally got underneath and looked at the axle. I googled around to find out what numbers to get, all I could find (dark and tight floor space) were the casting numbers on the front/input side of the case.
I think it was 3894860-N. The 0 might be a 6 or a G. Not sure if this tells me the axle contents or just the casting number/date. on the top there is also a GM12 cast into the case.
When I google that number it really just comes back with some random forums talking about GM axles, etc.
Is there another number somewhere that might ID the axle?
Oh also found out it did have dual exhaust. Not sure if that helps id the engine or not. Or maybe that would be something to do w/ the mystery option codes (but doubtful exhaust options would be on the trim tag)
Also, if interested here is the instagram where I am posting photos of the progress.. (its easier to post there than here)
https://www.instagram.com/67impalass_vert/
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
11-29-18 07:53 AM - Post#2752779
There is a code stamped on the front of the axle tube (not case) on the passenger side of the rear axle assembly. This will tell you the gear ratio, date and plant.
You will probably need to clean the axle tube to see the numbers.
Refer to Warren's http://impalas.org/drivetrain/ and scroll down to "Rear Axle Numbers".
Edited by BigDogSS on 11-29-18 07:55 AM. Reason for edit: No reason given.
Execution time: 0.099 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:00 AM
