Username Post: Yanking my engine out tomorrow        (Topic#353598)
Dorian
Dorian
Loc: Willebroek, Belgium.
Reg: 04-12-01
10-25-18 05:24 AM - Post#2749509
Hey all,
I am yanking the engine out of my 1969 tomorrow. I have pulled the engine out of my Chevelle a dozen times over the years... but it had an automatic. I have never dealt with manual.
Are there any tips with dealing with a manual box? Should I pull the engine out with the trans? What specifically would I have to unbolt or drop there... speedo cable,...
TAT_2
Member #26 "19th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
10-25-18 05:59 AM - Post#2749515
    In response to Dorian
PLUS THE Z BAR & DISCONNECT THE SHIFTIER LINKAGE.
HERS A VID,BUT ITS WITH A AUTOMATIC. /BASICALLY THE SAME PROCEDURE.
value="transparent">
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANIV- RUBY RED- LT1/6SPD/RAG TOP
NEXT ?
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
10-25-18 11:46 AM - Post#2749541
    In response to TAT_2
I always pull the transmission with the engine because it's a lot easier to put the trans back on the engine when it's out of the car. The only real issue in pulling an engine out of a C3 Corvette is that most engine hoists are not long enough to reach, so you will most likely have to come in from the side. I pull one of the front tires off in order to not interfere with the hoist. Good luck.
36, 38 & 39 2dr sedan, 41 coupe, 54 convertible, 56 Nomad, 57 210 2dr sdn, 70 Camaro RS, Corvettes; 57, 61, 65 396 coupe, 67 427 convert, 72 T-top, 88 coupe,91 ZR-1, 07 Z06, 16 Z06, 07 Silverado, 09 BMW 135i vert.
wagonmaster
Member #241
Loc: Loganville, Ga.
Reg: 04-28-00
10-27-18 07:42 AM - Post#2749675
    In response to bowtiefan
Good advice on side pull and removing the tire....You'll be glad you did!
Good luck!
Hey T @!
Joe
Dorian
Dorian
Reg: 04-12-01
10-29-18 03:47 AM - Post#2749834
    In response to wagonmaster
And... we did it !
Thanks, Gents !!
TAT_2
TAT_2
Reg: 10-29-00
10-29-18 05:30 AM - Post#2749844
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Execution time: 0.081 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:18 AM
