Username Post: Replacement Valve Cover Gaskets?        (Topic#353572)
Willow
Reg: 05-25-12
10-23-18 05:46 PM - Post#2749369
Greetings All:
1984 Vette. Advice needed for a good sealing valve cover
Gasket? Also, any tricks to seal good? Last question .
Can we replace Valve Cover bolts with studs and nuts to make install easier? As always, Thanks for your input.👍😊
TAT_2
"18th Year" Silver Supporting Member, and Official CT Grim Reaper
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
10-25-18 04:17 PM - Post#2749565
    In response to Willow
PERSONALLY I LIKE CORK GASKETS & PERMATEX #2.I PUT THE GASKET ON THE VALVE COVER 1ST & LET IT SET UP OVERNIGHT.BOTTOM I PUT IT ON B4 I PUT THE COVER ON THE HEAD.
IF YOU CAN GET A STRAIT DROP ON THE STUDS I WOULD USE THEM.OR JUST 2 TO GET IT LINED UP 1 TOP 1 BOTTOM.x PATERN TO TIGHTEN UP,A LITTLE AT A TIME,DONT OVERDO IT.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Execution time: 0.085 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:36 PM
