Username Post: rattle can primer.        (Topic#353523)
J C
J C
Loc: Orange Co. Calif
Reg: 04-17-04
10-19-18 11:17 PM - Post#2749099
I plan on sanding off surface rust on my van roof. I probably will do this over a period of weeks. I don't want to get out the spray gun each time. I would like to use a rattle can metal etching primer. All I hear is bad things about rattle can poor quality paint. Is there a product that is good and I can get in Calif. The Democrat government here has ruined many products by altering the formula or removing them from the market.
69RSZ28 71 Chevelle 79 Silverado 24K mi.
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
10-27-18 07:04 AM - Post#2749673
    In response to J C
The "other government" doesn't give a rats patoot what gets put it the air, water, or food.
Tommy
49 Deluxe Sport Coupe, 55 235, 700r4, Blazer rear axle, 4 wheel power disc brakes.
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
10-29-18 08:23 AM - Post#2749868
    In response to tommy49
Yes, but you have go to an automotive supply paint store. Talk to them about what you want to do. There are many in Orange County.
I buy mine from:
Sav On Supplies
13880 N Harbor Blvd # 6B
Garden Grove, CA
(714) 554-0036
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
Edited by BigDogSS on 10-29-18 08:24 AM. Reason for edit: No reason given.
J C
J C
Reg: 04-17-04
10-30-18 10:19 AM - Post#2749994
Tommy. You should come out here and live under that government who does give a .... about what goes into air and food. See regulations, taxes and many other thing that they jack up and eliminate or restrict.
J C
J C
Reg: 04-17-04
10-30-18 10:21 AM - Post#2749995
    In response to BigDogSS
Thanks Big Dog. Didn't know about that one. Used to shop at Betz in Orange but they are gone. The one by my place is somewhat helpful but can't get any real helpful info from them. Just called them and they said they do have a rattle can metal etching primer. We'll see. Thanks again.
Edited by J C on 10-30-18 10:26 AM. Reason for edit: No reason given.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
11-26-18 03:48 PM - Post#2752447
    In response to J C
I use this product for small jobs. You can use it to hold you over until a more permanent solution is found or until you can get it done with an actual two part epoxy primer.
LINK:
https://www.amazon.com/U-POL-Black-Primer-45 0ml-Ae...
1951 Fleetline
tkruger
Reg: 07-19-18
03-04-19 12:24 PM - Post#2761286
    In response to RAM_51
I went to where I am buying my paint with this same problem. They handed me a can and said use this and you will have no issue with any of our paint. Their basic advice was know what type of paint you plan to use in the end and they will match it with a comparable rattle can.
The other advice I was given is that I only need a real light coat to stop the rust.
03-04-19 06:08 PM - Post#2761313
    In response to tkruger
Any one part rattle can primer is not going to be a good foundation for a paint job. If you must use it, make it a temporary thing and be prepared to remove it prior to the real paint job.
05-26-19 10:37 AM - Post#2767116
    In response to J C
zinc chromate primer. a bigger paint store may be able to brew you something up and put it in a rattle can. shelf life will be short.
RAM_51
RAM_51
Reg: 12-28-02
05-28-19 04:42 PM - Post#2767248
    In response to bobb
LINK:
https://www.eastwood.com/2k-areo-spray-epoxy-p rime...
1951 Fleetline
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
06-11-19 08:52 PM - Post#2768280
Tommy I'm in full agreement with you. I've seen what
they did to your water in Michigan.
Execution time: 0.106 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:26 AM
