Username Post: AcDelco R45 vs. R45s sparkplugs        (Topic#353521)
Belair1956
Reg: 10-19-18
10-19-18 09:41 PM - Post#2749097
Hey all, I’m new here!
Car specs: 56 bel air air 265 fully stock convertible w/gen and voltage reg.
I was getting black smoke so I changed out very old spark plugs and wires. Bought AcDelco R45S and wires, changed them out one at a time and it fired beautifully. Within minutes I heard a ting-ting-ting and the smoke returned. Is it possible for the piston to strike the extended electrote tip and short? Is it more likely early detonation? Could I have “over torqued” the plugs and could I have damaged the piston?
Thanks!
Edited by Belair1956 on 10-19-18 09:43 PM. Reason for edit: No reason given.
10-20-18 03:54 AM - Post#2749101
    In response to Belair1956
Welcome to CT. Take the plugs out and look at them, you will if they hit the pistons.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
10-20-18 06:02 AM - Post#2749108
The extended tip on an"S" spark plug will not hit the piston on a 265-283. You may have loosened a piece of carbon or?
I would suggest removing the plugs and then spinning the engine over to blow out any loose carbon. At that time you can examine the plug tips.
The extended tip was made to burn off lead deposits on the plug that caused a high speed miss. Thankfully there is no lead in todays gas.
Belair1956
Reg: 10-19-18
10-20-18 06:53 AM - Post#2749110
    In response to Gene_Schneider
Removed all plugs and they look fine, I do have a fair amount of oil on the tip of #4 that I previously attributed to a bad vapor valve drawing oil from the valve cover into the carb, but this has been fixed....do i have a bad lifter/valve/gasket?
Edited by Belair1956 on 10-20-18 07:08 AM. Reason for edit: No reason given.
Execution time: 0.136 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:03 PM
