Username Post: sticky vent cables        (Topic#353430)
fander
fander
Loc: Hot Springs South Dakota
Reg: 04-28-12
10-13-18 09:21 AM - Post#2748565
If I apply lubricant to the outside of my vent cables will the lubricant work its way past the spiral wound wire and lubricate the inside?
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
10-13-18 10:08 AM - Post#2748568
    In response to fander
Probably not. Go to a motorcycle shop and buy a cable luber. It along with your favorite aerosol lube and straw should do the trick.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
10-13-18 12:16 PM - Post#2748578
put the entire cable in some penetrating oil (soak it) -something like DB blaster -works great...
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
junky
Loc: Northeast CT
Reg: 06-27-10
10-14-18 03:36 PM - Post#2748664
    In response to pvs409
I had good luck with spraying them with Deep Creep by Seafoam.
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
10-14-18 04:12 PM - Post#2748672
    In response to junky
I took mine out and hung them up and used the 3n1 oil.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
10-15-18 08:23 AM - Post#2748723
    In response to 69_BOWTIE
X2 I have done this on several vehicles. It takes a few days but it works.
I hang mine with a bucket under them to catch run off. I spray them several times a day for about a week.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Impalaserg
Impalaserg
Loc: Illinois
Reg: 03-07-12
10-18-18 08:12 AM - Post#2748966
Tri-Flow oil works great
pvs409
pvs409
Reg: 01-10-05
10-18-18 05:23 PM - Post#2749002
Paul
As I said just soak the entire cable in a oil drain pan( spray the cable 3 to 4 times). My cable was stuck now it works....
Paul
4EyedTurd
Reg: 02-04-14
10-18-18 06:22 PM - Post#2749006
Good to know, I’ve got two that are froze up, I’ll give that a shot
-64 Belair 6.0/6spd
junky
Loc: Northeast CT
Reg: 06-27-10
10-18-18 07:14 PM - Post#2749011
    In response to 4EyedTurd
The cables on my 1962 are plastic sheathed, so spraying the ends is the only way to get the oil into them. I have seen pictures of some that have steel wound wire sheaths, but not certain if they are replacements or originals. I can see soaking those, because the oil will penetrate the steel coils.
Execution time: 0.237 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:08 AM
