Username Post: Vortec injectors        (Topic#353416)
apratt89
Loc: Reno NV
Reg: 06-08-14
10-12-18 04:38 AM - Post#2748494
Truck is a 96 k1500 4x4. I replaced the fuel pressure regulator and fuel pump. I became curious and slid one injector out of the manifold. It looked to me like the injector was at the top of the manifold. It has a little fuel hose and a connector at the injector. Well I got curious again and went to the junk hard and took another truck apart. Now the injectors were completely different. The injector was at the bottom of the injector bore and there were no wires at the injector. Mainly my question is, will that second setup work in my truck. It seems more efficient to ha e the injector down at the port rather than shooting down a hole... any education you guys can supply will be greatly appreciated.
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
10-12-18 02:54 PM - Post#2748529
    In response to apratt89
Sounds to me like you are describing your truck as already having the upgrade spider. Sounds like the junkyard truck had the original.
The upgrade setup with the wired connector and an actual injector at the base is the better of the two setups.
http://www.fuelinjector.citymaker.com/Vortec_spide...
apratt89
Loc: Reno NV
Reg: 06-08-14
10-15-18 05:46 AM - Post#2748718
    In response to 1983G20Van
Well that is comforting to know! Thanks for the info on that!
Execution time: 0.109 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:40 PM
