Username Post: 88 K 1500 Steering Column/ Bright Lights        (Topic#353403)
Blueseasons
Reg: 10-13-11
10-11-18 07:17 AM - Post#2748422
I took my steering wheel off to tighten up those Torx bolts. Took it for a ride the first time at night and found that my "brights" are on and the stem will not flex to click them off. I have to pull it apart to fix that. To ease my pain, can anybody suggest where I messed up when I put it all back together? Thanks
Edited by Blueseasons on 10-11-18 10:54 AM. Reason for edit: No reason given.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
10-11-18 12:31 PM - Post#2748442
    In response to Blueseasons
Unfortunately, yes. The actual dimmer switch is near the base of the column. It might be as simple as loosening the actual switch and wiggle the actuator rod to get it to seat back in the hole. Here’s a pic
Attachment: 16918F83-8B2C-47C3-9016-88AF9547F70B.jpeg (409.52 KB) 8 View(s)
Greg
'00 Explorer XLT 4.0 V6 Auto
Blueseasons
Reg: 10-13-11
10-11-18 02:05 PM - Post#2748449
    In response to CowboyTrukr
Ok. we will look for that. Thanks. Can I see this switch at the base or is it in the tube? It looks like it attaches someplace with those slotted holes.
Skribble93
Loc: Upstate NY
Reg: 02-03-18
10-11-18 03:09 PM - Post#2748452
It's on the outside of the column about midway facing towards the passenger side
If it's to loud your to old
93 K1500 Z71 step side ext/cab 5.7 shorty headers and 3in true duals. 3in body lift and leveling kit.
89 K1500 4.3 rotted frame dubbed parts rig Sold
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
10-11-18 06:05 PM - Post#2748461
    In response to Skribble93
lucky for you it is outside the tube on the driver side.
Likely the rod got tweaked during removal and install of the column.
The holes are slotted to perform adjustment
Old School GM fan FOREVER
Edited by rockfangd on 10-11-18 06:06 PM. Reason for edit: No reason given.
Execution time: 0.139 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:44 AM
