Username Post: Steering locks up.        (Topic#353391)
kwase
Reg: 05-05-12
10-10-18 11:30 AM - Post#2748339
I have a 61 Impala with a 605 steering box. I recently installed new hoses and had the box rebuilt. I also installed a CPP centerlink kit to replace the original one that has that little metal ball going to the pitman arm. Now when I steer it will lock up after a few turns of the steering wheel. If I cut the car off and jack it up a little to relieve pressure on the tires it turns just fine. But when I cut the car on and lower it and steer it a couple times it will just lock up. Has anyone ever encountered this?
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
10-10-18 07:41 PM - Post#2748381
    In response to kwase
Was the 605 working correctly before the rebuild? I suspect there is now something wrong with the mechanical part of the gear because of poor assembly.
Jalapeno
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
10-11-18 03:38 AM - Post#2748402
Are you sure the center link is in correctly? The idler arm on the passenger side has to be correct to are it will bind up.
Ask me how I know.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
kwase
Reg: 05-05-12
10-12-18 02:00 PM - Post#2748522
    In response to Jalapeno
The steering box was just fine before the rebuild. I took it back to them and they said they tested it and it was fine.
kwase
Reg: 05-05-12
10-12-18 02:02 PM - Post#2748523
    In response to Andy4639
I will double check the center link tomorrow. the steering works just fine when the car is off and it's lifted a little off the ground. I just got a new pump that I'm going to install tomorrow and we'll see how that goes.
56_Kruiser
56_Kruiser
Loc: St. Augustine, Fl
Reg: 09-23-05
10-12-18 02:51 PM - Post#2748525
The angles of that linkage changes with weight on the wheels. That is why the nuts on a couple of them aren't torqued while in the air, but with the wheels on the ground.
1956 Chevy
Vid of 61
61 Chevy
Execution time: 0.397 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:31 AM
