Username Post: Fuel line        (Topic#353390)
Aldjjm
Reg: 04-01-13
10-10-18 10:05 AM - Post#2748334
Hi I'm looking for the fuel line from tank to pump for my 55 Chevy 2dr I'm installing a 327 with Holley 4bl. The body is off the frame and was looking for a pre bent line. Most places I've been checking sell the ones for the original 265 4bl with power pack heads. I don't know if that will work or not. Thanks
Mr. Sinister
Mr. Sinister
Loc: Fair Hill, MD
Reg: 05-18-09
10-10-18 10:37 AM - Post#2748343
    In response to Aldjjm
Danchuk sells a pre-bent line in 3/8" (plenty to feed a 327) for around $60 if I recall correctly. I'd also make sure you have a 3/8" pickup in the tank, or it will negate the benefit of running the larger fuel line. I'm also a big fan of running a return line to keep fresh, cool fuel circulating all the time, so if you need to upgrade your pickup to 3/8", you can get a return style 3/8" pickup from them as well.
Bill -
55 Chevy 210 2 Door Sedan
http://imgur.com/a/CfOc6
Execution time: 0.101 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:01 AM
