Username Post: msd ignition system        (Topic#353388)
teddybear15
teddybear15
Loc: Thatcher Az
Reg: 08-25-15
10-10-18 07:42 AM - Post#2748329
got a 1988 chevy s 10 4.3 swaped to a 5.7 just want some opinons on msd ignition systems. what do you think about them.. thinking about takeing the computer system out of the truck.
1988 chevy S 10 4x4 had a 4.3 swap to a 1988 chevy 5.7 engine came out of a K 1500 truck 4x4
Skribble93
Loc: Upstate NY
Reg: 02-03-18
10-10-18 10:37 AM - Post#2748342
    In response to teddybear15
It's a good system varies on what your looking for be it performance end or just better ignition system really even with just an upgraded coil, cap/rotor and wires you can get similar if just looking to amp up the ignition system. Performance wise it will do well also take in consideration if motor is stock or has been worked a bit can only get so much from the stock 5.7. I know there are other wiser gearheads on here that will know more just going from experience on my end.
If it's to loud your to old
93 K1500 Z71 step side 5.7 shorty headers and 2 1/2in straight pipes. 3in body lift and leveling kit.
89 K1500 4.3 rotted frame dubbed parts rig Sold
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
10-10-18 04:11 PM - Post#2748365
I just put the new MSD street fire in mine. It was easy to install. I have 10.5:1 compression and with 93 octane I either had to retard the timing to around 28° or richer the mixture to about 12:1 or I'd get spark knock at about 2000 rpm light load. The multi spark seemed to cure that.
The only complaint I have is it evidently causes some kind of radio interference. My reception goes to crap as soon as I start the engine.
Jeff
teddybear15
teddybear15
Loc: Thatcher Az
Reg: 08-25-15
10-10-18 09:17 PM - Post#2748392
    In response to bowtie44s
i am having a fuel problem or a ignition system problem with this truck. took all the plugs out and cleaned them then ran the engine for about 30 min. took 2 plugs out # 1 plug was carbon up again along with # 2 plug.
Execution time: 0.096 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:16 PM
