Username Post: Installing Bed floor in 59/60 El camino Sealant ?        (Topic#353382)
1belair1954
Reg: 12-24-12
10-09-18 11:06 PM - Post#2748299
Hi everyone finally getting close to installing the original bed floor in my 1960 El camino .
Does anybody know is it a good idea to use sealant between the floor to the frame. When I took it off it seemed to have some sort of white sealant around the bolt holes and around the sides and at the front not sure if this was added later.
Is it a good idea to try and make it waterproof so water wont get in underneath and start the rusting process over again ?
Also what is recommended I was thinking of a non hardening mastic sealant any ideas appreciated ?
I do not want something permanent in case I need to take the bed off again also.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
10-10-18 03:41 AM - Post#2748312
    In response to 1belair1954
I wouldn’t bother sealing it, I doubt you could get it 100% and it’s unlikely to rust once it has been properly painted. I have some old pics of under the bed in mine if I can find them. Don’t remember if there was any sealant, it likely would have been dum dum if anything.
Member #2194
stevelegel
stevelegel
Loc: Detroit MI
Reg: 09-27-09
10-10-18 04:56 PM - Post#2748369
    In response to DonSSDD
I wasn't considering sealant under mine as I am close to finishing. Then again, I don't expect mine to be weathered very much. I 'll look to see if I made drain holes in the bottoms of the footwells that are under the bed panel...hhhhmmmmm
My bed panle floor was rusted about 14 inches from the bulk head and there was a ton of leaves and dirt and junk underneath. I found someone who alos had a rust bed panle and bought 2 ft of his good end nad spliced them together after making a jig to position it. I calculated the underside support location and set the holes for the bolts etc.
1belair1954
Reg: 12-24-12
10-10-18 08:53 PM - Post#2748388
    In response to stevelegel
After all the work replacing the rust under my bed i will make sure it never sees water. I will be drilling drain holes in my replaced pans also. I might not seal mine then as it could become a pain to remove the bed later. I still can see the location of the original drain holes in my old cut out pans so will duplicate them.
Edited by 1belair1954 on 10-10-18 08:54 PM. Reason for edit: No reason given.
DonSSDD
DonSSDD
Reg: 08-21-01
10-11-18 12:08 AM - Post#2748396
I checked my pics, it may have had sealant- dum dum- only on the edge at the back of the cab. I see no evidence of anything anywhere else.
Member #2194
stevelegel
stevelegel
Loc: Detroit MI
Reg: 09-27-09
10-11-18 03:58 AM - Post#2748410
Do you think the sealant "seals the water in"?
1belair1954
Reg: 12-24-12
10-12-18 12:25 AM - Post#2748480
What is Dum Dum ?is that a tar like substance ? I am from Australia never heard of that word.
I noticed whoever was applying the thick tar like rust proofing in my El camino got huge dollops of it everywhere. A real pain to remove.
DonSSDD
DonSSDD
Reg: 08-21-01
10-12-18 02:33 AM - Post#2748486
Its more like a putty that doesn't harden. It was used around the windshield a lot, it was used to prevent leaks and also as an "anti rattle" substance I believe.
You can buy 3m Strip-Calk, its virtually the same stuff.
Member #2194
1belair1954
Reg: 12-24-12
10-12-18 03:08 AM - Post#2748488
Thanks Don
59cheviac
Loc: the sunshine state
Reg: 10-31-03
10-12-18 07:16 AM - Post#2748508
I bought a 59 El Camino decades ago where someone had used axle grease under the bed floor as a preservative! It must have been a quarter inch thick over the entire area, and was a royal pain to remove, but it did a great job of preserving both pieces!
Execution time: 0.082 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:13 PM
