Username Post: 1968 69 Impala Biscayne parts        (Topic#353317)
Howmac
Loc: Manitoba ,Canada
Reg: 01-30-07
10-06-18 04:07 AM - Post#2747973
Doing some Fall cleaning of excess parts :
- 1969 Impala & Biscayne ( 2 door) parts available:
Impala Doors 2 DR ( some with glass)
Biscayne/ BelAir 2 DR -post doors ( RARE) with tinted glass .
Custom Coupe glass ( door and rear 1/4).. tint or non tint
Fender , Inner fenders , Trunk lids , Hoods, Radiator supports, NOS rear lenses, 4 spd parts
- 1968 Impala / Biscayne Parts :
Bumper Filler panel , Lower Front Valance , Front Grill support brackets, Biscayne / BelAir rear bumper ( both Used and NOS ) and lenses, Floor shift columns , 4 spd parts
Please inquire .....
Located in Manitoba Canada . Can / will ship from Pembina ND 58271 if required
68 - 69 B Body enthusiast
Edited by Howmac on 11-04-18 04:55 AM. Reason for edit: No reason given.
bry593
Reg: 10-07-13
10-08-18 09:47 AM - Post#2748143
    In response to Howmac
I need the cable assembly for the LH kickpanel. This is a push-pull knob on the kickpanel, which operates a cable/wire attached to a door on the center HVAC manifold. These normally fail where a U-clip fastens the push-pull end to the kickpanel. I probably also need the U-clip since it has been a few years since I had my eyes on it.
Got another want. My horn button shorted the other day (thank you aftermarket crap!) and both horns blared until coil melt down. Thus, I need a pair of '69-'70 horns. Not sure what other years fit.
Edited by bry593 on 10-08-18 09:49 AM. Reason for edit: No reason given.
69 RAG
69 RAG
Loc: Newfoundland
Reg: 02-19-16
11-08-18 10:20 PM - Post#2750848
Hi Howmac. Looking for the insert for a 4sp console. Mine is auto but going std Thanks. Jim
Howmac
Reg: 01-30-07
11-10-18 07:07 AM - Post#2750968
    In response to 69 RAG
Jim , the 4 spd console is totally different than the AT consoles. The only thing that is interchangeable is the compartment lid , front cap and the chrome mouldings. Awhile back I helped out another fellow with a conversion from AT to 4 spd and it is pretty extensive ( if you want the factory look) . This is the list I created for him on what is required to do a factory correct 4 spd conversion on a 69 Impala
Muncie 4 speed transmission ( 69 and up)
Bell Housing #3899621
Clutch assembly (69/70 only)
4 spd crossmember ( unique ) ( convertible is also different as it is shorter)
4 spd shifter mounting bracket with trans brace and trans support rod ( Impala only)
4 spd Muncie shifter with rods and trans levers ( 69 trans levers only 3588 Reverse , 0235 M1-2 , 0236 M3-4 )
Shifter handle ( console version only)
Shifter handle knob - Chrome
4 speed hump ( extremely rare)
4 speed console -woodgrain (69 only)
Console upper and lower boot
4 spd floor shift column (not AT) ... 69 only
4 spd pedal assembly ( clutch rod etc..) 69/70 only
Neutral safety switch
clutch springs
Z bar 69/70 only ( has indent for back drive rod ) 3954621
Clutch fork - B body only... ( its flat with no bends) # 3860005
Bellhousing ball stud ( internal one )
Clutch Fork Ball Bell housing stud
Clutch Fork push rod # 3859863
Clutch rod firewall boot (unique 69/70 only)
Reverse lock out / back drive assembly and rod ( Muncie only)-extremely rare and difficult to find
proper length drive shaft
Edited by Howmac on 11-10-18 07:09 AM. Reason for edit: No reason given.
69 RAG
69 RAG
Loc: Newfoundland
Reg: 02-19-16
11-16-18 04:05 AM - Post#2751527
Thanks Howmac. A lot of information there I have some parts here. Would you have the console. Jim
Execution time: 0.074 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:28 AM
