Username Post: 1980 camaro headlight problem        (Topic#353299)
panthersl56
Reg: 04-05-14
10-04-18 06:48 PM - Post#2747883
Driver side headlight low beam doesn’t work, only works when put in on high beam, I checked the connections to the bulb and the headlight wire works when I use a test light but the low beam doesn’t work, so I’m assuming it’s not my bulb. I looked at the wires behind it and doesn’t look cut or pinched. The headlight just randomly went off.
10-05-18 05:20 AM - Post#2747895
    In response to panthersl56
So you have power and ground on the low beam connection?
panthersl56
Reg: 04-05-14
10-09-18 07:39 PM - Post#2748288
No power coming from the low beam wire but power to high beam and have ground
DECEASED
10-10-18 11:31 AM - Post#2748340
The first place to check would be the dimmer switch. Note that I said check, not replace. If the switch checks out good, look for a break in the low beam wire between the switch and the headlamp.
Execution time: 0.122 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:53 AM
