Username Post: vibration in floor        (Topic#353256)
jrhopkins
Loc: washington state
Reg: 12-23-16
10-01-18 10:30 AM - Post#2747615
feeling some vibration through the floor and gas pedal at highway speeds (60+) I don't feel it in the steering wheel or see any side mirror vibration. wondering if it could be a drive line out of balance or maybe u joints?
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
10-01-18 05:34 PM - Post#2747650
    In response to jrhopkins
I'd also check your motor mounts.
Gary
ragtp66
ragtp66
Reg: 12-09-07
10-01-18 05:45 PM - Post#2747653
Lots of possibilities. Bad tire balance or even a shifted/broken belt in the tire. Bad U joints/carrier bearing. I have seen a bad drum cause a nasty vibration too. Rear axle bearings. Just have to do a lot of narrowing down. Personally I like to start with the options that do not cost any money first. Swapping tires/brake drums, checking u joints, carrier bearing, motor & trans mounts.
Toys:
1987 Sea Ray Pachanga 22
jrhopkins
Reg: 12-23-16
10-09-18 08:12 PM - Post#2748289
    In response to ragtp66
going to start with the tires. rotate rear to front( radials) and see if that helps. I also thought maybe motor mounts. car was restored about 10 years ago and a 350 installed but don't know if the mounts were the same or replaced.
JayChicago
JayChicago
Loc: Chicago
Reg: 01-03-13
10-19-18 08:52 AM - Post#2749045
Sorry for the late reply here.
I'm going to suggest the center drive shaft bearing be checked. Common problem with X-frame cars with the two-piece drive shaft. The bearing is held in its support housing by a rubber ring to insulate vibrations, and that rubber can deteriorate with decades of use/age.
You say a 350 engine was installed in the past, and I would assume a more modern transmission also. The new trans probably required shortening the drive shaft, which changes the drive shaft geometry a little, may add to the chances of vibration.
An aftermarket center bearing is available from all the usual vendors, and not too difficult to replace. The bearing is pressed on, so that step would require taking the drive shaft to a shop that can handle that. And they can also check the shaft for out-of-balance.
Execution time: 0.089 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:04 AM
