Username Post: Replace Powerglide with TH350/400 or ?        (Topic#353247)
BrookwoodBob
Reg: 09-24-18
09-30-18 12:55 PM - Post#2747546
I'm trying to find out if there's a conversion kit/method to swap out a PG trans to something more modern in my '58 Brookwood with the 283. I want to keep it column shifted.
Edited by BrookwoodBob on 11-24-18 06:41 AM. Reason for edit: No reason given.
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
09-30-18 01:05 PM - Post#2747547
    In response to BrookwoodBob
A 350TH would be the easiest and most economical method. There's several other options such a 2004R, 700R4, tremec 5 speed, and others at a much great price tag.
Gary
rcochran
Loc: FERNDALE WASHINGTON
Reg: 07-20-13
10-01-18 04:40 PM - Post#2747642
Hi Bob, as a fellow Brookwood owner i have been wondering the same thing. the pg that i have leaks like crazy, even after a rebuild.
ragtp66
ragtp66
Reg: 12-09-07
10-01-18 05:37 PM - Post#2747652
There are several ways you can go. Do you know what rear end gear your running? Are you happy with your highway cruise speed? (engine rpm). If your happy with that then the TH350 is almost a drop in. If you want lower engine speed at highway cruising then the 700R4/2004R options are a little more hassle but very worth the effort. The 700R4 pairs up very nicely with a 3:73 rear gear. Several sources for crossmember and depending on which tailshaft length T350 you may not need to modify the driveshaft. Lots of options. All of them can be made to work with the column shifter.
Toys:
1987 Sea Ray Pachanga 22
rcochran
Reg: 07-20-13
10-02-18 05:16 PM - Post#2747721
    In response to ragtp66
Thanks for the info
Bel Air kiwi
Deceased Member RIP
Bel Air kiwi
Reg: 04-24-14
10-03-18 05:57 AM - Post#2747754
Hi Guys, I have a V8 305 th350 combo and its great but if I was starting from scratch I would want the overdrive series of 700R etc.
Better open road cruising revs and economy.
But be very aware with some of the later transmissions, post th350, if you mess up the TV settings they will burn up inside. The angle and settings of that cable are critical.
If its an infrequent use around town sort of vehicle then the bulletproof th350 will be fine.
Cheers Kiwi
BrookwoodBob
Reg: 09-24-18
10-03-18 04:55 PM - Post#2747811
Thanks Ragtp66. While replacing the transmission is no big deal, having a good working steering column with the proper gear indicator is my biggest challenge. This wagon will be my wife's cruiser so she will need to know exactly where Park, Neutral and Drive are I'm hoping there's some kit out there that makes this issue possible.
Execution time: 0.195 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:41 AM
