Username Post: Headlights go out.        (Topic#353221)
Nicksd
Reg: 09-02-09
09-28-18 02:51 PM - Post#2747426
I have a 1955 chevy convertible with a chevy 350 and a 700r4 trans. When I drive at night the headlights go out and than come back on about 30 seconds later. How do I fix this. I have a brand new lite switch?????
09-28-18 05:47 PM - Post#2747438
    In response to Nicksd
Sounds like the circuit breaker in the headlite switch is tripping. This happens due to an overload in lite circuit, see if it happens with just the parking lites on. If not focus on the headlite wiring, or if you have halogen lites they can overload the switch.
09-29-18 06:42 AM - Post#2747464
Did you change the switch because the lights were blinking or did the lights start blinking after you changed it? Could be a bad switch. The thermal breaker may be too weak.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
10-01-18 12:36 PM - Post#2747626
If your brand new lite switch is a china knock off, it't probably bad.
If you have gone to halogen headlamps, you may need to install a relay. That will keep from pulling too many amps through the switch itself, and may cure the problem.
Any good parts house will stock a RY-30 relay, and pigtail.
Griff
Attachment: RY-30photo_primary__ra_p.jpg (45.86 KB) 4 View(s)
Attachment: pigtail.jpg (10.81 KB) 5 View(s)
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
Execution time: 0.368 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:25 AM
