Username Post: Headlights go out.        (Topic#353220)
Nicksd
Reg: 09-02-09
09-28-18 02:49 PM - Post#2747425
I have a 1955 chevy convertible with a chevy 350 and a 700r4 trans. When I drive at night the headlights go out and than come back on about 30 seconds later. How do I fix this. I have a brand new lite switch?????
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
09-29-18 11:09 AM - Post#2747492
    In response to Nicksd
Sounds to me that you need a relay in that system
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
10-07-18 09:06 PM - Post#2748088
The 55 light switch has 2 sets of circuit breaker contacts. One is for the headlights.
Here's the entire shop manual online: http://chevy.oldcarmanualproject.com/shop/1955/ind...
Here's the page that shows the circuit breaker contacts: http://chevy.oldcarmanualproject.com/shop/1955/55c...
First make sure you aren't overloading the headlamp circuit. If you are certain you do not have an overload in the circuit, adjust the headlight circuit breaker contacts by bending the contacts apart just a touch. Best to do this with the battery disconnected.
Good luck.
Jalapeno
Edited by Jalapeno on 10-07-18 09:06 PM. Reason for edit: No reason given.
Execution time: 0.065 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:39 AM
