Username Post: 95 LT1 heater hose restrictor valve replacement (direction)/system bleed        (Topic#353201)
Highlander1
Highlander1
Loc: SE North Carolina
Reg: 08-19-04
09-26-18 07:56 PM - Post#2747306
My in heater hose (lower) restrictor valve broke.  Replaced it with a straight thru pipe. Engine overheats after short drives and gurgling can be heard after shutting down.
Have read that this valve is also important to cooling as the restrictor helps force hot water to radiator for cooling so planning to add aftermarket valve.
Replacement restrictor valve has an arrow on it. Should it point towards the firewall (my guess) or towards the front?
Any advice or link for proper bleeding of air from system would be appreciated.
Thanks!
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
12-30-18 08:40 PM - Post#2756054
    In response to Highlander1
the restrictor should be on the bottom hose pointing to the heater core
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
Execution time: 0.109 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:42 AM
