Username Post: Car just barely runs        (Topic#353180)
Philips68
Loc: Longmeadow, MA, USA
Reg: 08-06-01
09-25-18 12:57 PM - Post#2747181
My 84 ran just fine until one day it backfired through the intake. I let it go and it did it again the next day and then began to run very, very rough. It will start and idle just fine but under any load it breaks down and backfires. Shop has gone through all of the obvious ignition and fuel problems and can't find a solution. I want to ask them to remove the catalytic convertor...it feels like the engine is "choking". But there haven't been any symptoms to point to the CAT, like the smell, etc. Please help!
09-26-18 07:01 AM - Post#2747239
    In response to Philips68
Is this a tuned port or Vortec engine?
TAT_2
Member #26 "19th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
09-26-18 03:05 PM - Post#2747277
ITS A CROSSFIRE,2 TBI'S SITTING SIDEWAYS.
A BLOCKED CAT USUALLY ACTS LIKE A JAKE BRAKE SINCE THE EXHAUST HAS NOW WHERE TO GO & JUST BACKS UP.IF ITS LIKE A 85 OR LATER THE CAT IS BOLTED ON,SO ITS NOT THAT HARD TO REMOVE.
IT COULD BE JUST A BAD CAP WITH CARBON TRACTS,BAD WIRE,LOT OF RESISTANCE & ITS JUMPING INSIDE THE CAP.
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANIV- RUBY RED- LT1/6SPD/RAG TOP
NEXT ?
Philips68
Reg: 08-06-01
09-26-18 03:45 PM - Post#2747281
I guess it is a Vortec. It has cross-fire injection. It is not a TPI
09-26-18 04:46 PM - Post#2747290
Ok, crossfire, fuel pressure checked, clean fuel filter?
Edited by Shepherd on 09-29-18 01:29 PM. Reason for edit: No reason given.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
09-29-18 05:18 AM - Post#2747458
I just had a 84 crossfire in the shop that ran awful, Turned out to be the rubber hose on the fuel pump "in the tank" was deteriorated.
Execution time: 0.143 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:06 AM
