Username Post: 1957 rear axle bearing        (Topic#353167)
muzzy
Reg: 07-22-14
09-24-18 05:48 PM - Post#2747121
Looking for some help in finding the correct width rear axle bearing for my 1957 Chev as all the ones I have found so far are wide the same as 1958, the diff housing is all stock 1957.Also need to be really good quality as well. Thanks Guys.
Edited by muzzy on 09-24-18 07:04 PM. Reason for edit: No reason given.
09-24-18 07:28 PM - Post#2747123
    In response to muzzy
The 57 bearing is approximately .906" wide, part # RW307R. Rock Auto has a Timken, that seems to hold up well.
f.i.57chevynut
f.i.57chevynut
Loc: Granada Hills, CA
Reg: 03-04-09
01-16-19 09:57 PM - Post#2757583
    In response to acardon
If you want to put any miles on that bearing you'll get much more life out of an original GM New Departure or NDH bearing, NOT just a Delco bearing. I bought a bearing from a dealer years ago and the box said "Delco Bearing" but it was a BCA brand bearing. They don't last. The number number is 904262 but the bearing and ring part number is 904278R.
Tom Ordway tom@57chevys.com If you don't drive it, why have it?
http://www.americantorque.com/page/0/139/
Edited by f.i.57chevynut on 01-16-19 09:59 PM. Reason for edit: No reason given.
Execution time: 0.103 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:18 PM
