Username Post: door adj. ?        (Topic#353054)
rod
Member #248 Senior Member
Loc: kingman,az
Reg: 04-29-00
09-17-18 04:06 PM - Post#2746454
my old 67 Panel truck has seen way to many rough roads. the striker is a low as it will go and I have to put a bit of down pressure to get the driver door to close [with out slamming-which I hate]
2 questions then.
1 if I pull all 4 striker bolts out, will the threaded striker plates fall or are they captured inside the door pillar? [my 76 Suburban front door plates fall inside]
2. do you have to remove the front fender to lower the door hinges?
thanks Rod in AZ
JimKshortstep4x4
Chevytalk Moderator & "16th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
09-24-18 04:47 PM - Post#2747107
    In response to rod
The striker plates will fall out! I use strip caulk to hold the shims together when assembling.
I use an "S" shaped box end wrench for getting to the bolts.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
Execution time: 0.084 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:04 AM
