Username Post: convertible top relay        (Topic#352995)
coolcar348
Reg: 12-21-17
09-14-18 05:44 PM - Post#2746181
On a 1959 convertible there is supposed to be a relay inside the drivers side kick panel that goes to the top switch. Does anybody know where I can get one or how I could replace it with something else? Without it I just keep blowing fuses.
junky
Loc: Northeast CT
Reg: 06-27-10
09-14-18 07:16 PM - Post#2746190
    In response to coolcar348
I know that on the 1962 convertible, GM used a 30 amp circuit breaker, and a wire from the starter fed the breaker located in the left kick panel. I checked group 14.490 for a circuit breaker in my parts book, and it had no listings at all. It referred back to 13.095 group, and that only listed a relay for the power seat. I suggest checking your factory assembly manual for a part number, and I can check more with that number.
Aussie_Chevy_Nut
Aussie_Chevy_Nut
Loc: Australia
09-15-18 03:56 PM - Post#2746260
    In response to junky
GM might have used the circuit breaker for a power window setup ss well.
59cheviac
Loc: the sunshine state
Reg: 10-31-03
09-16-18 06:51 AM - Post#2746303
    In response to Aussie_Chevy_Nut
The same relay was used on the wagons with the power tailgate window. Sometimes you can find them listed as such.
59cheviac
Reg: 10-31-03
09-16-18 06:58 AM - Post#2746304
    In response to 59cheviac
https://ebay.us/XsvEF4
59cheviac
Reg: 10-31-03
09-16-18 06:59 AM - Post#2746305
That one will work just fine.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
09-16-18 03:33 PM - Post#2746352
NAPA etc sells these that will work, not correct but they work.
Member #2194
Edited by DonSSDD on 09-18-18 01:46 AM. Reason for edit: No reason given.
coolcar348
Reg: 12-21-17
09-17-18 11:36 PM - Post#2746493
Thank you guys for all the help. I ordered it from ebay today.
Execution time: 0.678 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:31 PM
