Username Post: frame paint        (Topic#352953)
5557mad
Reg: 11-17-11
09-11-18 06:26 PM - Post#2745942
having my frame blasted then wanting to paint it. what should i use for primer and paint
09-13-18 05:27 PM - Post#2746097
    In response to 5557mad
If you can afford it, have it powder coated by a reputable coater. If not, I don’t have any firsthand experience with it, but Eastwood sells chassis paint.
1957 Cameo Carrier
TAT_2
"18th Year" Silver Supporting Member, and Official CT Grim Reaper
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
09-14-18 03:01 PM - Post#2746174
RUSTOLIUM
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Senior Chevytalk Moderator
09-16-18 07:50 AM - Post#2746313
    In response to TAT_2
POR-15 vs ZERORUST vs other. I've used both POR15 and zerorust. I went with ZeroRust for my frame and entire engine bay. It was sprayed on. It's almost like a gun metal color. After several years, it's holding up great.
64chevyclassic
64chevyclassic
Loc: Moorpark Ca
Reg: 01-09-13
10-19-19 02:38 PM - Post#2778251
Por-15 is the way to go
65_Impala
Reg: 12-29-02
10-21-19 04:34 PM - Post#2778456
Use proper autobody primer and paint on clean blasted surfaces. 2-part epoxy primer and a quality single stage paint. Will stand up much better than garbage paints like POR15 or the like. Might as well Tremclad it if you're going to use POR15.
If you need to see it, I can get pictures of a project I painted with POR15 following their instructions. This project has been kept in a dry heated since it was painted 4 or 5 years ago yet rust is coming through the POR15.
lone star
Reg: 08-24-08
10-22-19 03:56 AM - Post#2778490
    In response to 65_Impala
YES. just use a 2 part epoxy primer. mixes 1 to 1. super easy to spray and u cant mess it up. will hold up longer than anything besides powder coating
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
10-25-19 04:28 PM - Post#2778763
To me I would like to know how you are going to use the car first. Say a car just for high end shows I would use fillers to level all uneven areas.
I used POR on the 30 Ford frame and it had a look I was fine with. With clean metal be sure to read all the tech sheet.
Execution time: 0.108 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:59 PM
