Username Post: '55 Chevy front brakes for '52 pickup        (Topic#352951)
widall2
Reg: 01-04-09
09-11-18 02:11 PM - Post#2745929
Will the front brake assembly from a 1955 Chevy car fit on a 1952 pick up spindles?
1950Chevrolet
Loc: SW Pa.
Reg: 09-09-18
09-13-18 05:08 AM - Post#2746025
    In response to widall2
The brake should be the same type on both, Bendix. The shoe size and drum might be different.
But the drum assembly with bearings might fit the truck spindle as is. I assume we are talking 1/2 ton?
DECEASED
09-13-18 12:44 PM - Post#2746050
The 55 car backing plates will not fit the truck spindles. If your original backing plates are damaged or missing, you can use any 51-55 first series 1/2 ton truck front backing plates. In case you aren't already aware, the car shoes and most of the other brake hardware (but not the drums or wheel cylinders) are the same as used on the 1/2 ton trucks.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
09-16-18 08:05 AM - Post#2746318
Hi Widall, Are you aiming for 5 studs or 6 stud wheel mount with those brakes?
Cheers Kiwi
Execution time: 0.107 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:37 PM
