Username Post: Checking generator's output on the car        (Topic#352936)
prgm_mgr
Reg: 07-06-05
09-10-18 12:44 PM - Post#2745818
Hello
Is there a way to check the output of a generator while it is on the car? I suspect mine is not working properly.
Thank you
Mark
09-10-18 05:02 PM - Post#2745837
    In response to prgm_mgr
With a volt meter connected to the battery, momentarily ground the field terminal on the generator, the small wire, careful, the voltage should jump to at least 14v or more.
prgm_mgr
Reg: 07-06-05
09-10-18 06:24 PM - Post#2745843
Do I need to disconnect the wires from generator first? Thanks
09-10-18 06:28 PM - Post#2745845
No, leave everything as stock, connected, just ground the field wire, that will put the generator in full output, 20 seconds is enough.
prgm_mgr
Reg: 07-06-05
09-11-18 06:34 PM - Post#2745936
Thanks!
Execution time: 0.298 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:06 PM
